03-07-2013, 02:34 PM
Re: want to install my corbeau seat
Ballin' on a budget
My Ride: 86 Daytona TurboZ CS
Engine: 2.2 tI
If you are any good and some minor fab work then I would recommend test fitting the stock seat bracket on the bottom of the corbeau seat. If it all lines up then just bolt it on, if not then make some adapter plates to line up the bolt holes onto the stock bracket. And dont use cheap flimsy sheet metal use 1/4 to 1/2" steel plates then cut and drill to make the locations line up.
