Old 05-25-2004, 09:50 PM   #1
Window weather strip
My Ride: 1984 Daytona
Engine: 2.2L Turbo 1
Sorry could be Interior and Exterior but oh well, does anybody know where to get the door window seals that wipe the window when it goes up and down? The one that is attached to the door panel and the one on the outside? All of mine are hard and cracking. I went to the dealer today and was able to order the drivers inner and the pass. outer seals but the other ones are NS1. I was looking in JCW's cataloge but I didn't see them there. Mabey I will have to call them. Anybody? Thanks.
SwiftTech is offline
Old 05-25-2004, 11:04 PM   #2
If you're looking for 84 I can help...
Outer belt weatherstrip (window sweeper) part #4198 670-1
Inner " " " " part #4248 492-3
I got a new drivers side outer a month ago. They are available. Call Troy Bray -- Performance Parts Dealer at Westoaks Chrysler Dodge. Aside from being a good friend of mine, he was patient enough to search for the parts.
His # is (805) 371-4900 and can ship the parts to you -- as he did for me.
Hope this helps
Aaron
85 Turbo Z
Los Angeles
Totally 80's is offline
Old 05-25-2004, 11:14 PM   #3
My Ride: 87 CSX
I don't know about the daytona but on a shadow you have to drill out the rivets on the door pass to get the old weather stripping out. The new ones snapped right in. In a Shadow the window has a plastic piece that hold the window in the channel. THey both broke when removing the window. Can also be bought at the dealer. They have a squeeze together rivet though and you have to squeeze it just right or it will not work. Buy 3 just in case you need an extra. Just some FYI as I just changed all the weather stripping in the CSX this year.
speed8988 is offline
Old 05-26-2004, 01:14 AM   #4
Images: 1
What year car are you trying to get them for?
Steve340 is offline
Old 05-26-2004, 03:44 PM   #5
they are for my 87 actually but they should be the same. the inner ones actually are stapled to the door panel and are a pain to get off. I don't know how I will reattach the new one that I took off already. I will give that guy a call and see if he can help. Thanks.
Old 05-26-2004, 05:58 PM   #6
My Ride: 87 CSX
I was talking about the channel in the door you might not have those since it's a t-top.
Kevin
Old 05-26-2004, 09:11 PM   #7
Images: 1
The t-top ones (outside window belt weatherstripping) are not available anymore and only one side is avialable for the hardtop. I would buy 2 of the one side that is still available for the hardtop. You can get them to work for both sides. Also, the only difference between the t-top ones and the hardtop ones is a small notch that is cut out on the t-top outside door window wipers (called belt weatherstripping), which you can do yourself with a razor knife.
Steve340 is offline
Loans | Mortgage | Remortgaging | MPAA | Find Local Jobs
Page generated in 0.36096 seconds with 13 queries
