03-23-2005, 10:57 AM
My Ride: 1986 lancer ES
Engine: t1 135
i would also greatly appreciate some pictures of where your gauges are in your h cars, right now i have an a/f gauge mounted to the right and slightly below my steering wheel and to be honest it really sucks, My boost gauge is mounted underneath my 12 button traveler and that also isnt very good because i have to take my eyes of the road just to see my gauge. i was thinking a homemade a-pillar mounting with a scrap pillar trim would be awesome,just havnt gotten around to it yet... so post your pictures of your H bodies!!! thanks guys
03-25-2005, 10:33 AM
Engine: t1 135
thats where my boost and a/f are right now and let me tell you what a mistake they are,thats why i got a junkyard a-pillar moulding and im just gona screw the gauges there, muahhahaha,maybe later i can use little tiny cans of some sort that the round gauges fit in well and make my own gauge pods with bondo and fiberglass
03-25-2005, 11:07 AM
I have 3 (well, only two gauges now since I removed one, but the mount still has 3 holes) in my Lancer.
I used a under dash 3 gauge panel mount like pictured in upper right of this picture:
Turned it upside down (just like it is in the picture), and bolted it to the top of the dash, right above the center vents. I Actually cut out the dash padding so the gauges wouldn't sit too high. Then I fabricated an aluminum cover to go over it, covered it in "dash pad" material, then painted to "match dash".
In this picture you can barely see the cover:
http://www.jescoonline.com/x/1988%20...r%20ES%203.jpg
Look right above the drivers side wiper, between the cowl and hood.
You may also be able to modify one of these:
As found on http://www.rpmoutlet.com/powerpod6.htm.
I have better pics of the gauges at home. I'll see if I can remember to upload some of them.
03-31-2005, 05:06 PM
My Ride: 99 Cummins
Engine: 5.9
I only have one in my lancer now:
http://www.turbododge.com/forums/att...chmentid=10252
Took out the left dash vent and turned the air ducting towards my feet at bottom.. Matches dash just like its stock
04-01-2005, 11:07 AM
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I used a Lotek dual pillar pod for a Daytona in my Shelby Lancer and my brother's Lebaron GTS. Doesn't fit perfect, but the gauges are easy to read and it only required two holes be drilled into the pillar.
