I'm not sure if this is going to happen, but I'm starting this thread to see if it can turn into a viable option. This all started when 86-89 Lancer asked if there was a way to make his air intake hose clear his brake booster.
I titled this for G-bodies, but feel free to use for whatever models you want. I'm assuming that there isn't going to be an original equipment option, since I've only been able to find power master cylinders. Therefore, it will require an aftermarket solution.
I haven't checked, but seem to remember that Tom Allard used a manual setup for his RWD conversion.
Willwood has these, but I haven't tried to match up the measurements, and don't know what will be needed to make the rod work.
www.wilwood.com/MasterCylinders/MasterCylinderLanding
