Does anyone actually do this 16V swap anymore - Page 3 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 17Likes
post #31 of 37 Old 09-01-2017, 12:45 PM
My Ride: 1967 Plymouth Cuda
Engine: Slant 6, 225CID,3.7L
Re: Does anyone actually do this 16V swap anymore
May have found my "Cam Gear"!!!! it is off of a 1.3L/1.6L Suzuki Samurai/Geo Tracker, it is 40 tooth, same as the 2.2 Cam gear but with the same mounting type of the Neon SOHC cam gear,to match the 20 tooth "2.2" Crankshaft gear so the next is the timing belt length........does anybody know if the length of the timing belt affect the timing in general?
Turbo6cuda is offline
post #32 of 37 Old 09-01-2017, 04:42 PM
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1986 LeBaron Vert
Engine: MOPAR 2.2L
Garage
Ok, I got everything out so I could get some pictures, don't mind some of the strange looking background, I had the head on the truck tailgate and didn't want to slide it around on the tailgate. The intake I was told is from a Stratus 2.4L, the throttle body I set on it is the one from the 2.5L turbo, I since rotated the TPS 180 so it has room for the plugs. The head and turbo are supposed to be from an SRT-4 and the guy I bought it from tried to use it on a 2.2L block, even tried 2 head gaskets! If anyone is conversant with the cam ID numbers let me know if they look right. Thanks!
ID:	235698   Click image for larger version
ID:	235706   Click image for larger version
ID:	235714   Click image for larger version
ID:	235722   Click image for larger version
ID:	235738   Click image for larger version
ID:	235746   Click image for larger version
ID:	235754   Click image for larger version
ID:	235762   Click image for larger version
ID:	235778   Click image for larger version
ID:	235786   Click image for larger version
ID:	235794   Click image for larger version
Turbo6cuda likes this.
Bill Vose
1986 LeBaron convertible 2.2L turboII
1986 F350 Crew Cab DRW
2011 Flex Limited
85lebaront2 is offline
post #33 of 37 Old 09-01-2017, 05:54 PM
85LeBaront2 I would like to know more about the head, what is the big elbow fitting on one side above the freeze plug? and where is the oil drain for the head back to the block? just wondering for my conversion. I think i found my Cam gear its from the 8 Valve 1.3/1.6 Suzuki Sidekick/Geo Tracker/Suzuki Samurai....It is 40 tooth cam gear and has the same tooth design as the 2.0/2.4L and 2.2/2.5, Next is for the timing belt Length......
post #34 of 37 Old 09-01-2017, 06:04 PM
Engine: MOPAR 2.2L
Garage
I haven't actually put it together, I think big elbow is for oil drain back, he had two, one on the back near the belt, the other in the end of the head. I already have the crank sprocket, it is the one for the common block, the belt, I can look tomorrow and see if it has a PN on it.
post #35 of 37 Old 09-01-2017, 06:06 PM
85LeBaront2 Do you happen to know where he got the cam gears?
those appear to be 40 tooth also those might be exactly what Im looking for I just need one though for SOHC..
post #36 of 37 Old 09-01-2017, 07:29 PM
Engine: MOPAR 2.2L
Garage
I suspect he got them from FWD performance in Spring Texas. If they are the same as stock, any 89-94 2.2/2.5L should have them and the intermediate shaft and cam are interchangeable, just turned over.
post #37 of 37 Old 09-01-2017, 08:10 PM
yeah I went to FWD performance website they dont seem to list them anymore.
