2.0/2.4 head differences? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 9 Old 02-18-2015, 10:16 PM Thread Starter
My Ride: 84 rampage
I was curious if there really is a huge difference between the two heads. Such as chamber cc's, valve sizes, lift an duration of cams, or any other differences. I do think in 2000 they went to a square intake an exhaust ports but don't know much more. Any help would be awesome!
bobs84rampage is offline
post #2 of 9 Old 02-19-2015, 12:16 AM
TD Extreme User!
My Ride: 2017 Subaru WRX
Engine: 2.0l Boxer Turbo
Re: 2.0/2.4 head differences?
Only difference from what I remember (and this is for the head and valves, not the cams) the 2.4l and 2.0l DOHC heads were the same for the years. Only difference is the early head vs. the later head. The older head has larger valves if I remember correctly and can flow more air right off the bat, but both have great porting options. The later head does have more after market ability since it is the same head as the SRT head.
1983Rampage is offline
post #3 of 9 Old 02-19-2015, 09:16 AM
TD Hardcore User!
My Ride: 85 laser
Engine: 2.5 hybrid
The 2.0's have slightly better camshafts although they are all pretty lame, the exhaust valves and ports were made smaller on the later 2.4's for emissions, also the crankcase vent on the intake side was changed witch requires a different head gasket, it also appears that the head gasket cooling strategy was changed possibly to even out the water flow, the holes for cylinder 1 are smaller while they get progressively larger towards cylinder 4
jim34 is offline
post #4 of 9 Old 02-19-2015, 02:29 PM
TD Extreme User!
Something in addition to the responses above, the only real major change was the intake and exhaust manifold bolt patterns. Earlier heads and later heads have a different configuration. This means that an SRT4 intake manifold is not a direct swap for an earlier head, some machining is required for it to work, and that is if it will work which I do not know.
post #5 of 9 Old 02-20-2015, 12:07 PM
Super Pope
The Pope's Avatar
actually the cam size, in 16v terms is pretty big between the 2.0 and the 2.4. The 2.0 cams are over a 1,000 RPM higher in power range. Hugely helps the 2.4 to use the 2.0 cams, hugely helps an auto trans 2.0 to have 2.4 cams.
The Pope is offline
post #6 of 9 Old 12-31-2015, 11:49 PM
Garrett Booster
My Ride: little mopars
Engine: 2.0 T (DSM), 2 x 2.5 TBI, 2.2 T1, 2.2 T2, 5.2 Mag
I was curious, has anybody swapped a neon SOHC to a 2.2/2.5? I'm sure I'd give up a little power to the DOHC but factory difference was only 10hp, if I remember correctly. Swap might be slightly more simple and head easier to come by. I would think even the SOHC (16V neon) would still be way better than the 8V.
AndyJ01 is offline
post #7 of 9 Old 08-30-2017, 09:20 PM
My Ride: 1967 Plymouth Cuda
Engine: Slant 6, 225CID,3.7L
I am currently working on a SOHC 16V to a 2.2L only problem I have run in to is the Cam sprocket I don't know the Formula to get the right size and # of teeth, test fitting is good(no interference while valves are closed), the other thing was the Oil feed, as the DOHC already has a oil feed on the back of the head, I had to drill and tap on the back of the SOHC head, but all I lack right now is the Cam Sprocket.
ID:	235658   Click image for larger version
Turbo6cuda is offline
post #8 of 9 Old 08-31-2017, 06:27 AM
Yup, I also noticed that 2.0's has better camshafts when I was building with my buddy from DSRLeasing last week
LeonB is offline
post #9 of 9 Old 11-29-2017, 07:34 PM
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1986 LeBaron Vert
Engine: MOPAR 2.2L
Garage
I know this was 2 years ago, but can anyone elaborate on the difference in bolt patterns? I have what was sold to me as an SRT 4 head, exhaust manifold with turbo and a Stratus intake manifold. The Exhaust definitely looks correct for either an SRT 4 or PT Cruiser turbo 2.4L, it has the right end upper bolt hole ground off and the left hand upper bolt hole has no mating hole in the head, as a result I have 8 usable manifold bolts on a manifold originally set up for 10. Sounds like I may have a 2.0L head. Is there a way to tell from the cast in cam numbers which cams I have?
Bill Vose
1986 LeBaron convertible 2.2L turboII
1986 F350 Crew Cab DRW
2011 Flex Limited
85lebaront2 is offline
