Why not AWD - Page 14 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #196 of 212 Old 11-29-2015, 06:59 AM
TD is love, TD is life
Re: Why not AWD
Originally Posted by Importcaptive View Post
I've been thinking about this a lot too, what's making it more of a pain than say, an allardtom type thing with the RWD trans from a dakota??
This thread is opened in 2008, last reply was 2009, 6 yrs ago. The person you quoted last visit here was in 2011.
mmmkaycar is offline
Last Activity: 02-27-2011
As far as I know, there was no result from this thread. AKA, it's all talk, no go.
tryingbe is offline
post #197 of 212 Old 11-29-2015, 09:21 AM
Level 3 Supporter
89TonaVa's Avatar
My Ride: 89 DaytonShelby TII
Engine: 2.2 Turbo FMIC
Re: Why not AWD
Figured it was a good place to throw out ideas.
89TonaVa is offline
post #198 of 212 Old 11-29-2015, 12:15 PM
My Ride: 10 speed
Re: Why not AWD
Yeah. This is also the only thread that mentioned the eagle AWD system when I searched TD, and I'd rather bring up an older thread than start a whole new one.
Importcaptive is offline
post #199 of 212 Old 11-29-2015, 01:08 PM
My Ride: GLHS 958
Engine: 2.2 Turbo II
Re: Why not AWD
Well, does anyone have any experience with the van AWD setup?
From what I can tell from pictures the transfer case resides where the intermediate drive shaft would normally be.
INSATANSSEAT is offline
post #200 of 212 Old 11-29-2015, 04:25 PM
My Ride: 10 speed
Re: Why not AWD
Allwheel Drive Omni GLH SRT4
This guy built one, this thread details the process pretty well, didn't read all of it though.
post #201 of 212 Old 11-30-2015, 10:23 PM
TD Extreme User!
My Ride: '88 Shelby Z TII
Re: Why not AWD
Yup...I have a van and a Pacifica AWD PTU as well as the rest of the Pacifica driveline to the rear.
To say it's a "bolt on" is misleading, but it's close. It does require machine work and cutting/welding.
There is absolutely no reason the system won't/can't work (as opposed to the old school thinking that it was too weak).
Reaper1 is offline
post #202 of 212 Old 12-01-2015, 03:43 AM
Level 2 Supporter
My Ride: '89 Shelby CSX
Re: Why not AWD
Lotsaboost actually was on a thread here, and then posted info on turbo-mopar. He had posted what he had done to graft an AWD Caravan system to a 568 in an omni with the SRT4 engine. Here are photos of his work: AWD Omni GLH by Carlos Martinez | Photobucket
88C/S is offline
post #203 of 212 Old 12-07-2015, 11:38 PM
Viper9087's Avatar
My Ride: 89 Daytona Shelby
Engine: 2.2L Turbo II
Re: Why not AWD
Finding the AWD Caravan is like finding a purple unicorn now a days.
Viper9087 is offline
post #204 of 212 Old 12-08-2015, 04:53 AM
Re: Why not AWD
Aren't they all automatics as well?
If you did find one and had to do some welding, might as well just get a SRT-4 engine and make it RWD. SRAs aren't the best for handling and an AWD setup that is an automatic doesn't appeal as fun.
ishigakisensei is offline
post #205 of 212 Old 12-08-2015, 01:49 PM
TD Extreme User!
Re: Why not AWD
You can adapt the AWD to the manual trannies. That's the point. Also, there are fitment issues when considering the different engines. I don't remember exactly what they are off hand, but I know it has to do with the PTU unit interfering with the block/oil pan on one.
AWD Caravans aren't as "unicorny" as you'd think...depending on where you are. I am fortunate to be in an area where right now, they are fairly common.
Reaper1 is offline
post #206 of 212 Old 12-08-2015, 02:43 PM
Level 2 Supporter
Re: Why not AWD
Some people on this forum have more than one Caravan AWD setup/parts set aside. Maybe you can put out a request for someone to locate one for you. They're nearly as rare as hens teeth where I am. Only saw one, and that was 3 years ago.
88C/S is offline
post #207 of 212 Old 12-08-2015, 08:43 PM
My Ride: 86 Shelby Charger
Engine: 84 Rampage 2.2 Prospecter
Re: Why not AWD
The 2016 dodge charger has an awd option with the hemi. !
moparracer 35 is online now
post #208 of 212 Old 12-09-2015, 10:38 PM
Viper9087's Avatar
Re: Why not AWD
Now your talking going from a sideways motor to a rear facing motor.
The awd caravans were nice because the transfer case was bolt on and replaced the half shaft. the only fabrication it needed I believe was the rear axle, exhaust, and floor pans which shouldn't be a big project.
people were more concerned with the durability than the installation.
post #209 of 212 Old 12-10-2015, 12:46 AM
TD Extreme User!
Re: Why not AWD
I can tell you from personal experience that the Chrysler AWD components are larger than ANY DSM ever dreamed of being, as well as any 3/S cars. The components are designed for a 3500+ pound vehicle, fully laden, AND towing with a torquey V6 (200-245ft-lb). Put those components in even a 3000# car and you are already WAY ahead of the game. Even lighter vehicles will put even less stress on the parts. Because of that, they can deal with quite a bit of abuse. I've seen videos of AWD vans and Pacifica's doing snow donuts and rough non-paved road stuff pretty well.
Now, I will say that I don't know anyone that has really shock loaded one of these systems, and they do use a flex/vibration dampening coupling on the multi-piece drive shaft, so the durability of that component is unknown. However, that can be overcome.
The other unknown is the viscous coupling. While technically it is possible to make the system locked so you don't have to worry about the coupler, I wouldn't suggest that for a street car unless you got the gearing *just right*. The system intentionally has a slight mismatch in the front and rear gear ratios (about 1-2% IIRC). What this does is induce a slippage in the viscous coupler that puts it on verge of "lock" (more like bind, but I could write and entire post on how they work) so that if the front tires do spin just slightly, it will pretty much instantaneously send more power to the back.
The 3000GT/Stealth use this same technique except the coupler is contained within the transmission. For our set-ups the coupler is external of the rear differential housing on vans. The Pacifica uses a slightly different set-up that is much more compact and the coupler is internal to that unit. I don't know if later vans got that set-up as well as I've not been around one long enough to poke my head under it.
Reaper1 is offline
post #210 of 212 Old 12-10-2015, 10:54 AM
Garrett Booster
My Ride: '89 Dodge Daytona ES
Engine: 2.5L | Dead
Re: Why not AWD
Yeah, I never understood why people said it would get trashed so easily. Have you people seen the way Caravans are treated?
The van is somewhere around 4000lbs. That means it's load on the transmission is cut by 25%, which I'm sure would equal out by you hooning on it a lot. It should be fine.
After I get the 3.8L swapped in my Daytona I'll see how much work it will take to get the AWD on it. Being there's already a driveshaft tunnel on them, it shouldn't be too much fab work.
WarlockSyno is offline
