1994 Lebaron convert Hemi rwd project - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 35 Old 03-02-2014, 09:23 PM Thread Starter
My Ride: 1994 Lebaron and 192
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Lightbulb 1994 Lebaron convert Hemi rwd project
Well, moved her in the shop today !.... Here we go. Tomorrow start making marks on the firewall before pulling interior like heater box and floor console height etc. ordering kit from Kenny tomorrow have triangle kit coming, Hemi is all complete ready, the ranger(sorry)8.8 373 posi there as well. Kenny said a week or so he should have it ready to ship. Pulling 3.0 this weekend(know anybody needs a good running 3.0/automatic). Sat there and made plans and took forever like 6 months or so.....but 5 minutes to move her in !! Will be posting picts. as I go. Any advice will be appreciated..... Take care and talk to ya soon.
Lebaronguy is offline
post #2 of 35 Old 03-02-2014, 10:17 PM
Garrett Booster
My Ride: 1998 Dodge stratus
Engine: I4 2.4
Re: 1994 Lebaron convert Hemi rwd project
HEMI in a Le Baron? Keep us posted!
classicfan1 is offline
post #3 of 35 Old 03-03-2014, 09:21 AM
My Ride: 88 Lebaron 'vert.
Engine: 408
I left the airbox in mine and cut around it, so as not to take out any more than needed. I only took it out to finish welding. Depending on your transmission choice, you may be able to leave the top of the center reinforcement alone.
Brace the hell out of the back half before you start cutting, it WILL move around.
Gearhead24-7 is offline
post #4 of 35 Old 03-08-2014, 10:08 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Well, stripping it down has and is a long project itself.... I have a little interior left then the cutting begins........
ID:	112114   Click image for larger version
post #5 of 35 Old 03-10-2014, 06:42 PM
Garrett Booster
My Ride: Hemi Daytona's
Engine: 6.1L / 5.7L
I see you have a picture of the underside of my 88 Shelby. Check out the 1990 RWD conversion in this same forum and you'll see there is a lot better way to do this conversion.
Tom
allardtom is offline
post #6 of 35 Old 03-10-2014, 09:32 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Exclamation Re: 1994 Lebaron convert Hemi rwd project
Tom
Tom,
So sorry !...thought that I put the picture of taking out the interior but got this one instead.
again,
so sorry,
I apologize.
Tomorrow I will be showing you my progress on my Lebaron convert.
post #7 of 35 Old 03-11-2014, 10:25 AM
Garrett Booster
Engine: 6.1L / 5.7L
Lebaronguy,
No problem, I'm happy to see the pictures being used as a reference and I'm looking forward to reading your updates!
Tom
post #8 of 35 Old 03-23-2014, 10:39 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Ill be adding picts soon.... I received my k member kit and hemi mounts from Kenny Exline, bought a 8.8 ford rear from a 92 ranger 373 locker, triangler rear suspension from ebay rear coil-overs from checker racing and other several parts ......... I have all interior out, rear floor cut out, installing rear, and tomorrow installing frame connecters to my fabricated rear frame. I will take picts and lable them maybe tomorrow. I still need a bump steer kit - where are they the cheapest ??... Hopefully I'll have the chassis work done by the weekend... then transmission tunnel and fngine mounting will begin...PICTS coming hopefully tomorrow...If I get time...
post #9 of 35 Old 04-06-2014, 11:33 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Got the rear done ! now installing the motor and the a/500 ovetrdrive because I have the 8,8 rear with 373's
ID:	115642   Click image for larger version
ID:	115650   Click image for larger version
post #10 of 35 Old 04-12-2014, 11:26 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
Motor and tranny mounted today !!
Name:	motor and tranny installed.jpg
post #11 of 35 Old 04-28-2014, 08:00 PM
My Ride: 69 Valiant-93Shadow
Engine: 446-2.5
Far out!
Scrapmetal is offline
post #12 of 35 Old 05-21-2014, 01:38 AM
My Ride: Daytona 3.0 & 2.2T
Engine: 3.0 & 2.2T
Induct: Nitrous
If you don't have torque management, you might want to do something about that trans.
either find one that uses a slip yoke or youre gonna break the flex couplers or you're gonna be using heavy driveshafts for that car unless you have a custom made slip tube shaft.
I'd use another trans or change the tail to a slip yoke.
Supershafts is offline
post #13 of 35 Old 05-26-2014, 08:39 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
It is a slip yoke. Thanks anyway ! broke my arm on the april 28th so I have been working on other stuff like painting the engine compartment and TRYing to scrape and bedline the underneath.....Depressinggggggg.....Does anybody know if I should use the factory throttle pedal ? my tranny tunnel seems to be in the way. I was thiking about relocating the brake pedel to the left. JUST the pedal...not the arm. I Will be posting a pic of the engine compartment tonight yet when it is done downloading.. Thanks
post #14 of 35 Old 05-27-2014, 10:05 PM
My Ride: hemi 92 daytona
Engine: 5.7 hemi
I used use the original throttle pedal and moved it over about an inch and also bend the brake pedal to move it over a little also.
exline is offline
post #15 of 35 Old 05-28-2014, 11:21 PM Thread Starter
Engine: Hemi 5.7
Induct: Nitrous
1/4: 11.190
set the motor in.. picts and thanks for the info. Kenny ! there is a mock up pict and a completed pict.
ID:	122729   Click image for larger version
Name:	engine compartment painted.jpg
ID:	122737   Click image for larger version
Name:	engine installed.jpg
