Those bugatti injectors sound pretty neat. ondonti i was(am) going to use 560cc evo8 injectors which is like 55lb hour. what do u think. according to all the charts thats how big i need to run big power on race gas.
You will need an external pump added to your system to really support that kind of HP.
I would suggest a Denso 044 pump. about 250 bucks but you will be good for 800hp on gas safely. Run that with your current intank walbro.
In tank walbro will crap out LONG before you max out those injectors. With the external 044 you will also be able to crank up pressure if you want and extend the size of those injectors to maybe 60lb
I suffered a lot over the years with the intank walbro. It just didnt like the high pressures I forced it to see with the BEGI RRR.
I waited too long to upgrade my fuel system. If I was staying FWD forever then the Denso 044 would have been perfect for me.
lol you were not kidding when you said you wanted to copy my intake filter setup. Looks like the AA body has a LOT more room between the radiator and the engine. My P body doesn't fit the filter well even with the hood spaced upwards.
I love how our engine bays look when setup like this. Open the hood and people drop their jaws.
thats the only place the air filter would fit!! i was going to stuff it down by the clutch linnkage but with the wastegate and stuff there aint much room down there. plus like u said i love the wow factor. yr right about the size differences. tried to put daytona rad in the t2 shadow and it dont work.
never had the bumper off. cut the corresponding holes by the headlights. intercooler sitts on 2 supports bolted to the bottom of the rad support. used 90degree rubber booties off of the intercooler to the charge pipes.
I originally thought I could get the filter to fit out towards the fender but that only worked on my smaller turbo setup that had a 3" turbo inlet and tiny ru3030 filter from my n/a setups.
I will post pictures of that thurs/friday when I get internet fast enough to look through imageshack(crap).
got sick of it, rusted too bad, wanted something better looking and light
ive always had a thing for 2 door shadows
but it turbed out the one i bought was no better shape then the spirit lol
that is the part number. but where do u get them from?
ps. i didnt know they made a shift kit for a 5spd:bash:
Related Threads
Turbo Dodge Forums
2.4M posts
56.1K members
Since 2000
