Fuel Gas Fumes in Warmer Weather - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 20 Old 12-21-2017, 11:10 AM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
My Ride: '87 GLHS #325
Engine: 2.2 135 C.I.D.
Iím getting a faint gas smell from the gas cap on my 87 GLHS.
The tank has 5 gallons in it with Stability 360 added.
When I unscrew the gas cap, there is a lot of pressure released.
The gas cap is a new Chrysler piece.
The upper tank vent and grommet are sealed and in good shape.
The vent hose is new.
The F.I. clamps & hoses at the tank and fuel filter are new and tight.
The fuel send & return hoses at the fuel rails in the engine compartment are new and tightened.
There isnít any fuel smell anywhere but the gas cap, and only after there is a temperature rise.
Could it be the charcoal canister is clogged?
Jim
Jim Falco is offline
post #2 of 20 Old 12-21-2017, 09:03 PM
My Ride: '91 Daytona
Engine: 2.5L TI
Re: Gas Fumes in Warmer Weather
The filler grommet where the filler tube goes into the gas tank is one area to check as well.
bamman is offline
post #3 of 20 Old 12-21-2017, 10:37 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
canister could be an issue but so could the hose connecting it or the steel line running to the tank could be pluged up
with only fumes passing through it for 30 ish years it could be full of rust
take the cap off and try blowing air through the hose and line
something like a bicycle pump would work if you have no source of air
side note , years ago I had a buddy with an old volare
it would stall once in a while because the fuel pick up in the tank was clogging with junk
he would disconnect the fuel line , stick the hose from the bike pump on and pump the junk off the pick up screen
back on the road in 5 min
Dr. Johny Dodge is offline
post #4 of 20 Old 12-22-2017, 10:25 AM
My Ride: 86 Shelby Charger
Engine: 84 Rampage 2.2 Prospecter
Roll over valve in top of tank stuck
moparracer 35 is offline
post #5 of 20 Old 12-22-2017, 11:11 AM
Hybrid Booster
The L-body gas fill cap is suppose to release under excessive pressure or vacuum. Better make sure your fill cap is for the correct application. The L-body roll over valve and fill cap are unique to the turbo l-body. What you may be smelling is the fill cap doing it's job releasing excessive pressure. I would look at the charcoal canister, lines running to canister and to the TB, and the canister purge solenoid. My guess is either something is plugged, or the solenoid is not opening properly to purge canister.
4 L-bodies is offline
post #6 of 20 Old 12-22-2017, 11:12 AM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
I forgot to note:
I bought Permatex RTV sealant for gas and coated the filler tube grommet, & the rollover valve grommet with it.
The rollover valve looked ok, but yes it could be stuck.
post #7 of 20 Old 12-22-2017, 11:21 AM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
I replaced the expanded end hose with an NOS one, so itís probably ok.
Iím thinking youíre right about the charcoal canister.
Unfortunately theyíre no longer available and I havenít found anyone making an aftermarket one yet.
We removed and cleaned out the tank a few months back, and the pump and pickup were replaced with an NOS unit several years ack, & the filter sock was also replaced a year ago.
My brother has an air pump so weíll try blowing out all three lines.
I hope it isnít the rollover valve because Iíd hate to have to remove the tank again.
post #8 of 20 Old 12-22-2017, 11:26 AM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
I replaced the solenoid pack 2 years ago with an NOS piece so hopefully itís not that.
The cap is a Chrysler part for the L24 body.
Iím going to blow out the metal line that goes from the wheel well to the firewall for the canister.
I never thought to check the line from the canister to the throttle body though....thanks!
post #9 of 20 Old 12-22-2017, 11:34 AM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
Does anyone know if anyone makes an aftermarket charcoal canister for the L-body?
post #10 of 20 Old 12-22-2017, 11:58 AM
Level 2 Supporter
gkcooper's Avatar
My Ride: 1992 Daytona R/T
Engine: 2.2 TIII
Garage
My filler grommet was rotted into several pieces. You can still get them new though.
gkcooper is offline
post #11 of 20 Old 12-23-2017, 06:26 AM
Just A Guy
NAJ's Avatar
Just an FYI on what happened to me recently.
Over the past 8 month's or so I was smelling fuel near the back of the car and could not find anything leaking or any signs of leaks so I left it alone.
Then one day in the middle of October I filled up and when I got home (about 1/2 mile from the gas station) and got out of the car the smell of gasoline was really strong towards the back of the car.
I looked under the rear of the car and there was raw fuel dripping from the top of the tank and all over the undercarriage.
Turns out it was the rollover valve which is supposed to be a "one way valve" which it no longer was.
Luckily because of my OCD I had a Brand New Mopar Rollover Valve in my personal stock.
Fuel Smell has been gone ever since.
Jan
1990 Daytona Shelby VNT
post #12 of 20 Old 12-23-2017, 10:34 AM
Hybrid Booster
If you really severely overfill your fuel tank, you can also fill the charcoal canister up with raw fuel. My buddy Quack did this with his 86 GLHS once. His was dripping fuel out the right front of the car! There is a lesson there for you MPG mileage checkers (lol). Never seen an aftermarket canister.
post #13 of 20 Old 12-23-2017, 11:40 AM
Super Moderator
while the canister is gone from the parts list it shouldn't be too hard to find something similar from a more modern era car that also would use a purge soloniod and the same line in/out hook ups
it won't be the same but something like it should work the same
instillation shouldn't be hard either as it just gets stuffed in the fender well
post #14 of 20 Old 12-24-2017, 01:10 PM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
I tried to find a p/n for the rollover valve to replace it but couldnít.
Luckily there is no smell from underneath and no leakage anywhere near the tank, the filter, or any of the hoses.
Itís only at the gas cap itself.
Weíre going to blow out the lines and inspect all the hoses under hood this week coming up.
I havenít overfilled the tank ever, so thatís not the problem.
Iím hoping itís a clogged vapor line and not the canister itself.
post #15 of 20 Old 12-24-2017, 01:16 PM Thread Starter
Level 4 Supporter
Jim Falco's Avatar
Luckily it wasnít overfilled.
I kept the tank 3/4 full with Stabil in the earlier years of storage and now with 5 gallons of Shell V-Power Nitro+ gas with Stabil 360 mixed in.
