1995 2.5L Cold Issue - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 2Likes
  • 1 Post By NAJ
  • 1 Post By NAJ
post #1 of 6 Old 12-22-2017, 11:32 AM Thread Starter
CoupleOvans
6g72 acclaim's Avatar
My Ride: 94 Voyager
Engine: 3.8L
Got the cooling system all sorted on my 1995 Acclaim.
Now it has an issue on cold starts:
It will fire right up, idle for about 3 secs, then die. Turn it over again, same thing. Turn it over a 3rd time, it fires up, idles roughly for 10-15secs, then settles into a normal idle.
Plugs/wires/cap/rotor are all new, along with the whole cooling system. Outside of this issue, it runs very well.
6g72 acclaim is offline
post #2 of 6 Old 12-23-2017, 06:31 AM
Just A Guy
NAJ's Avatar
Re: 1995 2.5L Cold Issue
Your symptoms sound exactly like the problem we had with the Jeep Grand Cherokee's when they had issues with the seals in the Fuel Pump Module.
First thing you need to do is look at fuel pressure and fuel pressure bleed down.
Fuel pressure on a 95 TBI is 35-43 PSI and pressure should not drop quickly when the engine/fuel pump is shut off.
(A few pounds every couple of minutes is normal)
Once you have verified fuel pressure to be OK you need to look at the Baro Reading(Key On/Engine Off) from your Map Sensor.
6g72 acclaim likes this.
Jan
1990 Daytona Shelby VNT
post #3 of 6 Old 12-26-2017, 06:17 AM Thread Starter
CoupleOvans
My Ride: 94 Voyager
Engine: 3.8L
Ok, I will check these things out this weekend.
How do I go about checking the baro from the Map?
post #4 of 6 Old 12-26-2017, 06:32 AM
Just A Guy
NAJ's Avatar
Key On/Engine Off Voltage Reading.
https://www.turbododge.com/forums/f4/...agnostics.html
post #5 of 6 Old 12-26-2017, 09:01 AM Thread Starter
CoupleOvans
My Ride: 94 Voyager
Engine: 3.8L
Thank you.
Appreciate the help, as always.
post #6 of 6 Old 12-28-2017, 06:27 AM Thread Starter
CoupleOvans
My Ride: 94 Voyager
Engine: 3.8L
May not have to worry about it at all. Assuming it can be done, I may be pulling the drivetrain and swapping in a 98 3.3l/4-speed combo.
Sick of trying to straighten out the PO's issues with this engine.
