90 Degree Thermostat Housing - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 1Likes
post #1 of 18 Old 02-17-2018, 09:48 PM Thread Starter
Level 2 Supporter
Wildwest's Avatar
My Ride: 84 Dodge Rampage
Induct: S/C
This is for an 84 Rampage with the 2.2L non-common block, no turbo. I'm working on mounting an aluminum radiator to replace the stock one. In order to make it work, I'm going to need a.thermostat housing with a 90 degree angle. I have some flexible stainless steel hoses with adapters that will fit from 1" to 1 1/2" outlets.
I.would like to find a 90 degree tstat housing for the 2.2L that could work for my application. Swivel would be a plus, black anodized even better.
Thanks in advance for anyone's feedback or assistance with this.
Everything will be OK in the end. If it's not OK, it's not the end.
Wildwest is offline
post #2 of 18 Old 02-17-2018, 10:17 PM
My Ride: CSX/CS/GLHS
Re: 90 Degree Thermostat Housing
So you need a thermostat housing to hold a thermostat and that points to the passenger side rather than straight forward towards the radiator?
ILIKESHELBYS is offline
post #3 of 18 Old 02-18-2018, 07:10 AM
My Ride: 86 GLHT
Engine: 2.5L
Some of our vendors sell aluminum outlets, I think you're going to have to buy one and weld a 90 degree elbow on to it.
Keith Alto is offline
post #4 of 18 Old 02-18-2018, 07:17 AM
Level 2 Supporter
I was given one by another forum member and I was told it was from a 3.3L. approx 2000???
chromguy is offline
post #5 of 18 Old 02-18-2018, 12:24 PM Thread Starter
Level 2 Supporter
Wildwest's Avatar
Induct: S/C
Steven:
That is correct.
Keith:
I currently have an aluminum one w/O ring installed. I want to try and keep the cosmetics close to show quality.
chromguy:
Thanks for the offer, but I don't believe that will fit the 2.2L . If you're willing to let it go, i might just get it to see if it fits.
I've searched online, but as usual, they are for Chevy small blocks, or larger Mopar engines. Going to try searching and see if a Rabbit or Sicorro (sic) might have had one like that. Kinda grasping at straws here.
Wildwest is offline
post #6 of 18 Old 02-18-2018, 12:31 PM
A trip to the salvage yard might yield you the needed piece. I would take a standard 2.2 piece or a template w/me and see what might match up.
masterjr3333 likes this.
post #7 of 18 Old 02-19-2018, 06:52 AM
I think he is right.
I would take a stock thermostat gasket to the JY and start pulling.
see if you can find something close.
or something you can cut/weld onto a factory flange.
masterjr3333 is offline
post #8 of 18 Old 02-19-2018, 08:03 AM
Level 2 Supporter
chromguy is offline
post #9 of 18 Old 02-19-2018, 08:13 AM Thread Starter
Level 2 Supporter
Wildwest's Avatar
Induct: S/C
Steven, masrerjr
That was an option, just wanted to see if there was a part I could purchase first. It's warming up down here, just right to go junking.
Chromguy
Thanks for taking the time to find the link. However, I don't believe that a thermostat housing for a 6 cylinder would fit for the 4 cylinder 2.2.
Wildwest is offline
post #10 of 18 Old 02-19-2018, 10:43 AM
Level 2 Supporter
Originally Posted by Wildwest View Post
Chromguy
Why not believe??? Ma Mopar did lots of this stuff as it reduces engineering resources.
I just tested a few moment ago and it flips the flow 90 degrees on the horizontal plane with a slight upward on the vertical plane. The mounting holes match
Oh and the slight vertical will help the hose to clear the distributor cover/wires
chromguy is offline
post #11 of 18 Old 02-19-2018, 08:07 PM
TD is love, TD is life
What chrome says. I used a 3.3 thermostat gasket with a 2.4 thermostat housing on my 2.2 cylinder head.
tryingbe is offline
post #12 of 18 Old 02-19-2018, 09:01 PM Thread Starter
Level 2 Supporter
Wildwest's Avatar
Induct: S/C
WOW, I would have never thought that they would interchange. Thanks a lot chromguy and tryingbe!
So just to recap, a thermostat housing from a 2000 Grand Voyager 3.3L would fit on a 2.2L, is that right? It appears that one has the slight vertical to it.
Wildwest is offline
post #13 of 18 Old 02-20-2018, 08:29 AM
I would suggest going to a parts store. or looking online.
Get the part number for a 2.2 thermostat coolant outlet gasket.
Get the part number for various other 3.0 and 3.3 and 2.4 coolant outlet gaskets.
If you find one that has the same part number..
then it should fit.
post #14 of 18 Old 02-20-2018, 10:12 PM Thread Starter
Level 2 Supporter
Wildwest's Avatar
Induct: S/C
masterjr(etc):
Thanks for the advice. Finding a matching gasket would lead to an alternate thermostat housing. I wouldn't have thought to look for it that way.
Wildwest is offline
post #15 of 18 Old 02-23-2018, 07:43 PM Thread Starter
Level 2 Supporter
Wildwest's Avatar
Induct: S/C
chromguy, tryingbe:
You guys made a believer out of me! I went to O'Rileys, they didn't stock the Doorman part, but they had a Murray cross. Picked it up just to try it out, AND IT WORKED!! I just took it back and ordered the Doorman with the vertical, as it would indeed work better. Man, I can't thank y'all enough for getting me out of a pinch.
Wildwest is offline
