Fuel 1987 dodge shelby charger - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 2Likes
  • 1 Post By NAJ
  • 1 Post By signsoflife22
post #1 of 3 Old 11-13-2018, 10:19 AM Thread Starter
My Ride: dakota truck
Question 1987 dodge shelby charger
fuel problem ? no power to pump or fuse #10 on fuse block pump test good ,I have good spark and compression , good battery.no start ???? any body thank you ???? this one has got me ?????
doffer is offline
post #2 of 3 Old 11-14-2018, 08:16 AM
Just A Guy
NAJ's Avatar
Re: 1987 dodge shelby charger
Welcome To TD!!!
Power to the + Coil, Injectors and Fuse #10 comes from the ASD Relay which is integral to the Power Module.
If you have spark the ASD Relay is obviously working so power to the + Coil but not to Fuse #10 means there is a break in the wiring.
The power circuit runs as follows...(The ASD Relay Power Output is a DG/BK Wire)
1)Power Module 10 Pin Connector Cavity #6 to Cavity #32 of the Bulkhead Connector.
2)At the Bulkhead Connector the Power Feed Splits and runs Underhood to the + Coil and Fuel Injectors and through the Bulkhead Connector to Fuse #10.
I would start by checking power into the vehicle at the BH connector.
The ASD Relay will only be actuated for 1 second with initial key on then again when the controller see's a crank signal from the HEP.
You can manually actuate the ASD relay to make it easier to trace the voltage in the circuit.
MANUALLY ACTUATE THE ASD RELAY
1)Locate the underhood diagnostic connector
2)Place a jumper wire in the slot with the DB/YL wire and connect the other end to a known good ground.
3)Turn the key to the "on" position.
I will send you wiring through PM.
signsoflife22 likes this.
Jan
1990 Daytona Shelby VNT
post #3 of 3 Old 11-16-2018, 10:30 AM
TD Hardcore User!
My Ride: 1987 GLHS #0896
Engine: 2.2 8 valve
1/4: 11.000
NAJ is THE MAN around here, and is always willing to help out members; especially with diagnostics.
Rest assured that any advice he offers will be 100% accurate.
Originally Posted by NAJ View Post
Welcome To TD!!!
+1 for NAJ always being helpful
Sent from my iPhone using Tapatalk
MarkassBauer likes this.
signsoflife22 is offline
