Ignition key won't open trunk ? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 8 Old 05-16-2019, 11:42 AM Thread Starter
My Ride: 1995 Dodge Spirit
Engine: 2.5l EFI
Images: 6
Long story short....1995 dodge spirit, non-turbo, 2.5 efi. original key was lost. I have 2 all metal keys (not oem and have no rubber shoulder), which work fine in the ignition, but will not open the trunk. Any obvious reason for it to work in ignition, but not the trunk? And no, trunk lock cylinder was not changed.
Dad had another new key cut (not oem) with the proper "code" ?? but again, no worky in the trunk ?
omniac is offline
post #2 of 8 Old 05-16-2019, 12:33 PM
Garage
Those were the days that they offered a valet key (which is what you have) which only operated the ignition but prevented access to anything needed to be kept secure in the trunk. That means the trunk release inside the car also would have featured a key lock so it could be defeated and prevent access to trunk from inside.
Not sure if any dealers would still be able to determine and cut the correct “master” key to replace the one you lost....,
85dodge600es is offline
post #3 of 8 Old 05-21-2019, 06:57 AM
Its also possible that the key is right but one or more tumbler in the lock are sticky. Spray some pb blaster in the lock and run the key in and out a dozen times
Ridehard2001 is offline
post #4 of 8 Old 05-21-2019, 09:42 PM
EaZyE426's Avatar
My Ride: 91 Spirit R/T
Engine: TIII
Re: Ignition key won't open trunk ?
I have the same issue with my Spirit. It only came with the valet key. I took my registration to a local Chrysler dealer and had them cut a key based on the vin. It didn't work though. I plan on pulling the truck lock cylinder and having a locksmith change it to fit my current key, I also bought NOS key blanks to get cut and have a proper key again.
EaZyE426 is offline
post #5 of 8 Old 05-22-2019, 09:26 AM
Just A Guy
NAJ's Avatar
The "Valet" key will also not open the glove box if it is locked.
I used to be hardcore on keeping everything factory/stock when the car was new and I was younger but at this point in my life I like/want simple and easy
IMO, the easiest thing to do (less hassles, less headaches) is replace the key cylinder in the trunk, yes you will have two separate keys which I have anyway because I had to replace the ignition key cylinder.
https://www.rockauto.com/en/catalog/...cylinder,10597
Jan
1990 Daytona Shelby VNT
post #6 of 8 Old 05-22-2019, 10:43 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
these issues are what you get when you start using one of general motors bright ideas
no need for a valet key with the old ignition key / round trunk , glove box key
if/when you get the trunk open I'd look at the lock , find out which notch or bump on the original key would open the trunk and simply remove that particular tumbler and spring out of the cylinder .. if it comes apart
now every key you cut for it should work ..
issue's the lock , not the key
Dr. Johny Dodge is offline
post #7 of 8 Old 05-28-2019, 02:14 PM
My Ride: '91 Spirit R/T
The difference between the Valet and regular key is the width. You can make either key from the other. Depends on the blank. If one compares the keys, they look identical.
mccabet is offline
post #8 of 8 Old 05-29-2019, 01:31 PM
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
If you can removed the locks, this is how I solved having multiple cars and keys, and now having one key for all:
https://www.turbododge.com/forums/f3...witch-how.html
LaserDad is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
2004 2007 Dodge Caravan car ignition transponder key Chrysler key ID46 dodge cars forsale Caravan + Parts 0 06-30-2012 08:20 PM
How do you open trunk from inside ?? 86 lebaron convertible smith356 Exterior 4 07-10-2009 10:16 PM
92 shadow - ignition key won’t turn back. Shelby-Rampage Turbo Dodge Help 1 09-04-2008 04:35 PM
L body door won't open? GLHandGTS Turbo Dodge Help 4 10-14-2003 04:45 PM
