1988 Daytona Solenoids - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 16 Old 07-09-2019, 08:29 PM Thread Starter
Can someone show me how the solenoids on a Daytona are supposed to look like? It's a T2.
Ducktallica is offline
post #2 of 16 Old 07-10-2019, 08:03 AM
Level 2 Supporter
re: 1988 Daytona Solenoids
look like????
Physically? or do you want to know how they are connected?
Here is a document that can help. http://www.glmwpg.com/ServiceManuals/88p.PDF
chromguy is offline
post #3 of 16 Old 07-10-2019, 09:15 AM
Just A Guy
NAJ's Avatar
Re: 1988 Daytona Solenoids
Welcome To TD!!!
88 has three solenoids, Baro, Wastegate and Purge.
They are located in front of the right side (passenger) strut tower.
The wastegate and purge are combined solenoid assembly, the baro is separate.
You can find the baro by following the vacuum line from the Map Sensor it should be a standard 3 port universal solenoid.
All solenoids have three ports, vacuum/pressure in, vacuum/pressure out and a vent that remains open.
The only illustration I have for the "dual vacuum" wastegate/purge solenoids is in the Chrysler Parts Catalog (link is posted below, post 41 has working links)
https://www.turbododge.com/forums/f4...-pdf-82-a.html
1988 Catalog, Group 25 Emissions Systems, Page 1258, Figure 25-1500, Item 1
Universal Vacuum Solenoid On Left.
Map Sensor And Baro Solenoid
Jan
1990 Daytona Shelby VNT
post #4 of 16 Old 07-10-2019, 09:56 AM Thread Starter
Thank you guys for the information. So the car wont start and the the code its sending out is fault code 36 could the issue be that the wastegate door is stuck open? From what I can tell the everything for the selonoids are where they should be.
post #5 of 16 Old 07-10-2019, 11:00 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
two solenoids on the pass side inner fender
map / baro solenoid on pass side strut tower
(map is the one on top)
sorry best pic I have on hand
Dr. Johny Dodge is online now
post #6 of 16 Old 07-10-2019, 11:46 AM
Just A Guy
NAJ's Avatar
Only the Baro Solenoid could possibly create a "no start" issue if it did not allow any vacuum to the Map Sensor, the wastegate solenoid would only create an overboost or no boost condition, it has absolutely nothing to do with the car starting and running.
If you have a no start condition follow the instructions in the thread link below and post back.
(If after rechecking fault codes all you get is the Code 36 then continue with the diagnostics)
https://www.turbododge.com/forums/f4...k-84-90-a.html
post #7 of 16 Old 07-10-2019, 03:36 PM Thread Starter
So I was looking over the wires and vacuum lines and found this 2 wire plug. Do you know where this goes?
https://www.turbododge.com/forums/me...0-160403-2.jpg
post #8 of 16 Old 07-10-2019, 05:46 PM
Super Moderator
that should be for the intake charge temp sensor that should be at about the middle of the front of the intake - where the rectangular connector is in your pic
or it would be .. if the engine I were looking at were a TII but by the air cleaner box and hose to the throttle body in front of it .. I see a turbo one engine
that would not even have the bung on the intake drilled and threaded for the sensor to go in
only a TII would
what is your car ?
post #9 of 16 Old 07-10-2019, 05:56 PM Thread Starter
It's an 88 Daytona shelby Z so it should be a turbo II
post #10 of 16 Old 07-10-2019, 06:48 PM
Super Moderator
is it automatic or std trans
some shelby z's were auto - those cars are TI's..
post #11 of 16 Old 07-10-2019, 07:18 PM Thread Starter
It's an auto.
post #12 of 16 Old 07-11-2019, 10:16 AM
Just A Guy
NAJ's Avatar
Have you started the No Start Diagnostics yet?
post #13 of 16 Old 07-11-2019, 02:13 PM Thread Starter
I have not started the no start diagnostics and wont be able to for a few days.
post #14 of 16 Old 07-11-2019, 03:00 PM Thread Starter
So I searched the VIN and it came up as the 175 hp turbo II.
post #15 of 16 Old 07-11-2019, 03:31 PM
Super Moderator
then it's been "fixed" at some time over thirty years
could be a TII that had an intercooler leak
could be a manual to auto conversion
you'll have to look deeper into the car to see exactly what you have as many have been cobbled to hell to keep them going .. and THAT's not always a bad thing
two unused tabs anong the front edge of the crossmember right behind the diff would mean there WAS a 5 speed trans there once upon a time
