87 Turbo LM?ís - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 30 Old 07-11-2019, 03:45 PM Thread Starter
Hybrid Booster
My Ride: 92 Spirit N/A
Engine: 2.2 MPFI
87 Turbo LM?ís
Iíve got a LM from an 87 J-body Lebaron turbo, with the red and blue connectors and no spot for the MAP sensor(uses external under the hood). Just curious if this LM would use the later 4-wire AIS, or the 2-wire goofy one from the log manifold?
I never saw the car it came out of, so idk what manifold it had:(
I also donít know if itís a simple cut & dry question like Iím making it sound, or not...
MarkassBauer is offline
post #2 of 30 Old 07-11-2019, 04:03 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
Re: 87 Turbo LM?ís
it should have a sticker with the part number ..
post it if ya gots it
a painted or coated case would probably be a rebuilt one
Dr. Johny Dodge is offline
post #3 of 30 Old 07-11-2019, 04:46 PM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
P/N on this LM is 5233366
post #4 of 30 Old 07-11-2019, 04:52 PM
Super Moderator
Re: 87 Turbo LM?ís
https://www.turbododge.com/forums/f4...mber-help.html
see second post ...
post #5 of 30 Old 07-11-2019, 04:56 PM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
I knew it was a T1 Auto LM. Does that mean log intake would’ve been in that car? Was 87 T2 the only 87’s that didn’t use log intakes?
post #6 of 30 Old 07-11-2019, 05:34 PM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
If that is what it means, that’s a bummer. I will be in serious need of an 87 T2 LM, if that’s the case. I already converted my 87 TBI to the newer style T1 intake, TB, MAP and added the necessary wiring, but this LM might be fricking me...
post #7 of 30 Old 07-11-2019, 05:42 PM
Super Moderator
Re: 87 Turbo LM?ís
I'm pretty sure it would be the log motor
maybe ask about reflashing the second gen TI onto the lm ?
but ais would probably then be different
post #8 of 30 Old 07-12-2019, 06:33 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII .60/.63 2-piece SRT4 IC SMEC no B/S ;)
Re: 87 Turbo LM?ís
87 TI = log
but *yes* you can socket yur '86-7 TI LM,
then run a "TII" cal with either a 2-piece or 1-piece intake mani,
or even better- a custom 1-bar N/A MPFI cal,
and either will need the 4-wire AIS to function properly..
detobias is offline
post #9 of 30 Old 07-12-2019, 06:37 AM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
I like the sound of that, but have NO knowledge in doing anything like that..
post #10 of 30 Old 07-12-2019, 07:25 AM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
Are the PM’s any different between the 87 T1 and T2?
Does T2 still run the injectors in pairs like the T1 (1&2 and 3&4 together)?
post #11 of 30 Old 07-12-2019, 07:52 AM
Level 2 Supporter
Re: 87 Turbo LM?ís
Originally Posted by MarkassBauer View Post
Are the PMís any different between the 87 T1 and T2?
According to http://www.glmwpg.com/ServiceManuals/87p.PDF
all turbo PM are the same.
Yes all LM and SMEC are batch firing, For sequential firing you need a SBEC or SBEC2
chromguy is offline
post #12 of 30 Old 07-12-2019, 08:10 AM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
Ok, thank you!
post #13 of 30 Old 07-12-2019, 08:17 AM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
I think converting to SBEC might be my next move honestly
post #14 of 30 Old 07-12-2019, 09:41 AM
Super Moderator
Re: 87 Turbo LM?ís
there's challenges thar too...
simple solution is find the TII lm.. easy enough there's thousands of them out there
better is the DC/MP one .. but a lot harder to find .. and the swap to smec might be a better idea at that simple point
you could get away with a J body lebaron engine compartment and dash harness
BUT you'll have to give up the power mirrors or sort the mirror power and switching out after the fact
and you would have to splice in a set of headlamp motor connector
- J's only have one h-l motor so the lead is there but it has one connector in the center
post #15 of 30 Old 07-12-2019, 10:08 AM Thread Starter
Hybrid Booster
Engine: 2.2 MPFI
Re: 87 Turbo LM?ís
This is an 87 Aries TBI auto, I was just looking to keep it N/A, but add the T1 intake stuff for the fuel injection. The stock PM was blipping out everytime it was hot out and I already had the parts (newer T1 intake, and LM/PM from that 87 T1 Auto J body) laying around to swap what I thought was gonna work.
It runs, but seems pretty rich and if I put it in gear, it stalls unless I manually turn the idle way up.
I did a similar swap in my Spirit, with a flex fuel SBEC, but that was already an SBEC car, so clearly this would take a lot more wiring to run one of those. Although it does look do-able unless there’s something to it I’m not seeing...
I’d definitely rather have the sequential firing injectors as well
