Timing Question - Rotor Loctation - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 3Likes
  • 1 Post By raccoon1
  • 1 Post By detobias
  • 1 Post By tryingbe
post #1 of 5 Old 04-20-2019, 02:24 PM Thread Starter
Bib
Hi All,
89 2.5 Turbo Auto
First time doing a belt in my life. Plenty of chains although first belt.
Read the post associated with timing mark locations on the crank and intermediate shaft, oval in cam sprocket and lines visible thru cam sprocket holes.
Window on trans and timing marks on housing, Two timing marks on the convertor which made things interesting for a bit.
TDC confirmed at #1, piston at top of travel.
All looks good except for rotor location. Def not 10 o'clock. More like 11 o'clock although everything else looks dead one.
Thoughts please and thank you.
Bib
ID:	253783   Click image for larger version
ID:	253785   Click image for larger version
ID:	253787   Click image for larger version
ID:	253789   Click image for larger version
Bib is offline
post #2 of 5 Old 04-20-2019, 04:56 PM
Re: Timing Question - Rotor Loctation
I don;t even try to line up the mark for the intermediate shaft. I pull the distributor and have the slot for the distributor parallel with the block.
if I try to use the marks its always out a tooth and the distributor with sit funny, to set the timing you'll have to really turn it some, not the end of the world. as long and the cam and crank are correct.
I check the cam by taking a picture of the face of the camshaft sprocket and comparing the seam where the cam cap meets up. making sure its even on both side, its a pain to line up the center notch to space.
Bib likes this.
raccoon1 is offline
post #3 of 5 Old 04-20-2019, 06:17 PM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII .60/.63 2-piece SRT4 IC SMEC no B/S ;)
looks good, run it !
Bib likes this.
detobias is offline
post #4 of 5 Old 04-21-2019, 09:18 AM
TD is love, TD is life
Don't forget to set the ignition timing!
Bib likes this.
tryingbe is offline
post #5 of 5 Old 04-27-2019, 08:42 AM
Super Pope
The Pope's Avatar
The big one is tension the belt then look at the marks. Better than 90 percent that have timing issues don't do it. Yes after timing the dist slot should be parallel with the cylinders which is pointing at #1. My self I line up the bottom, turn the cam to the right a bit. Add the belt, turn the cam left to tension then check it. I also use my phone to view the cam pulley, used to use a mirror before smart phones lol
The Pope is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timing- How to adjust cam timing 1985ShlbyChrger Engine - General, Exhaust & Induction 3 07-19-2004 08:42 PM
can i check cam timing with a timing light? 87shelbyz Engine - General, Exhaust & Induction 2 04-09-2004 08:19 AM
distributer/ timing belt timing... TurboShadowES Engine - General, Exhaust & Induction 4 03-26-2004 01:28 PM
Timing Jumping aorund on timing light? 88lebaron Engine - General, Exhaust & Induction 5 02-22-2004 12:06 AM
Ignition Timing Without Timing Light 88lebaron Turbo Dodge Help 7 02-09-2004 03:45 AM
