How to actually use the Timing Tensioner Tool? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 4Likes
  • 1 Post By chromguy
  • 1 Post By Dr. Johny Dodge
  • 1 Post By NAJ
  • 1 Post By NAJ
post #1 of 12 Old 05-16-2019, 06:49 PM Thread Starter
Garrett Booster
My Ride: minivan
Engine: turbo 2.5
I bought a KD 3282 Tensioner Tool... and can find plenty of debate over if the tool is needed but no description of how to use it. Neither does the service manual describe a procedure.
Does one merely turn the tool on the tensioner until the front of the belt is 90 degrees tight when twisted by hand OR is there a particular angle, position, or method for use for the tool?
jimmytroy is offline
post #2 of 12 Old 05-16-2019, 09:47 PM
Level 2 Supporter
Re: How to actually use the Timing Tensioner Tool?
From Brian
jimmytroy likes this.
chromguy is offline
post #3 of 12 Old 05-17-2019, 01:18 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
make sure the block surface and the back of the tensioner are nice and clean
as per vid , line everything up and install the tensioner onto the engine , in place up against the belt
run it's bolt in until it swings around freely but it's more or less up against the block with the bolt almost tight
swing the tensioner into the belt loosely and install the tool so the weight is at about the 11:00 o'clock position
this leaves room for the weight of the tool to "fall" and provide what is supposed to be the correct tension
but you still have to tighten the bolt
sooo you need to also put your thumb on the tool at the weight and push down slightly to prevent the tensioner rotating as the bolt tightens
this would reduce your belt tension if it did
if it makes a lot of "chirping" when you start it the belt is to tight
to tight and to lose will also be indicated by where the belt rides on the cam pulley
ie , close to either the inside or outside edges vs more or less in center
I've NEVER used the twist the belt method I go by ear as that "chirping" sound just starts ever so slightly when the tension is "just right"
if to tight you get something that sounds like ERR ERR ERR ERR ERR ERR
most of the cars i've come across are err err err err err
just right is eh.....eh.....eh....eh
I hope this helps
once you hear things change as you make adjustments it will make more sense
I have always found though the weight of the tool alone is not usually enough
it needs the thumb push to prevent rotation when tightening the bolt , PLUS just a little more "thumb"
if you hear a TD running with the hood shut and there's a fairly loud running sound going
ERR ERR ERR ERR ERR ERR ERR
it's the timing belt and it's way to tight
Dr. Johny Dodge is offline
post #4 of 12 Old 05-17-2019, 07:14 AM Thread Starter
Garrett Booster
My Ride: minivan
Engine: turbo 2.5
From just looking, it seems like the weight could also be pushed against the block to prevent it from turning while the bolt is being tightened.
I'm not sure all 2.5 engines react to the tension with the same chirping as your engine?
I'm glad I bought the tool.
It seems like the primary objective "sweet spot" is proven by the gears not jumping a tooth on the belt.
It seems like the belt would loosen over time "stretch" even on the Gates brand kit that I bought from Rockauto.
post #5 of 12 Old 05-17-2019, 08:32 AM
Just A Guy
NAJ's Avatar
The FSM does show how to use the tool and properly tension the belt.
Although I use the tool to tension the belt and hold the tensioner in place while tightening I have never gotten tension correct by following the factory method.
Illustration #4 shows how to properly use the tool.
https://www.turbododge.com/forums/f4...n-84-95-a.html
post #6 of 12 Old 05-17-2019, 09:05 AM Thread Starter
Garrett Booster
My Ride: minivan
Engine: turbo 2.5
In conjunction with the belt/timing and shown in the FSM
I added some UV dye to detect my oil leak which is either the oil pan or crank seal. When I get the pulley off the crank I'll be able to see better (I already changed the pan gasket, maybe still leaking). If it is the crank seal, are the tools indicated for the removal of the crank gear and seal needed/useful?
post #7 of 12 Old 05-17-2019, 09:39 AM
Just A Guy
NAJ's Avatar
After hours of trying unsuccessfully to remove the crank sprocket without the proper tools my Son improvised a tool that worked easily and perfectly using the body of my OTC pitman arm puller and bolts.
https://www.tooltopia.com/otc-tools-7310a.aspx
post #8 of 12 Old 05-17-2019, 10:49 AM
TD is love, TD is life
How to pull timing sprocket with only bolts, nuts, and washers....
I would recommend trying my method first before using a jaw puller.
tryingbe is offline
post #9 of 12 Old 05-17-2019, 12:12 PM
Super Moderator
from the comment .. after hours of trying.. you can deduce that pulley is stuck the hell on there with what amounts to a force fit
it sure ain't a slip fit like a regular V8 harmonic balancer would be - why I'd like to know
so when you find it's difficult to remove .. or impossible it would seem .. that's what we call normal - your difficulty would not be unique so to say
it would have been nice if cryco hadda used a larger front seal and left the pulley on permanently
the moment you mentioned crank seal all our eyes rolled back slightly lol
(arugh)
post #10 of 12 Old 05-18-2019, 09:38 AM
Just A Guy
NAJ's Avatar
(arugh)
Not True, once we had a tool that fit properly it came right off without issue.
post #11 of 12 Old 05-21-2019, 10:45 AM Thread Starter
Garrett Booster
My Ride: minivan
Engine: turbo 2.5
After the sprocket, what is the procedure to remove and install the seal without the seal tool?
post #12 of 12 Old 05-21-2019, 11:51 AM
Just A Guy
NAJ's Avatar
Chrysler wants you to remove the housing and remove/install the seal on the bench but not absolutely necessary.
Removing can be done with a screwdriver/small pry bar/seal remover, just be careful not to nick the housing.
You can install the seal using a socket that is the same size as the seal, just be sure it goes in straight and tap lightly until it is seated.
Two Tips...
1)Pack the back of the rubber seal with wheel bearing grease to prevent the garter spring from popping out during install.
2)Coat the outer portion of the seal with a non-hardening sealer such as Permatex #2 or Permatex Aviation Cement which will fill any minor imperfections in the housing to prevent leakage.
BEARING RACE/SEAL INSTALLER
https://www.harborfreight.com/10-pie...ng+race+driver
SEAL REMOVER
https://www.harborfreight.com/search?q=seal%20remover
PERMATEX
https://www.permatex.com/products/ga...-no-2-sealant/
https://www.permatex.com/products/ga...ealant-liquid/
Jan
1990 Daytona Shelby VNT
Similar Threads
Thread Thread Starter Forum Replies Last Post
Can the timing belt tensioner tool be used with the cover on? ILIKESHELBYS Engine - Turbo & Block 6 06-29-2014 07:58 PM
timing tensioner special tool? 88shelbyZindet Turbo Dodge Help 11 06-26-2011 05:43 AM
Timing tensioner tool, starter harness and more Lebaronguy2001 Parts Wanted 3 04-24-2005 12:25 AM
U actually use premium? 3.0Daytona Turbo Dodge Help 37 05-02-2004 06:05 PM
clutch and timing belt tensioner tool (Michigan) ForceFed Wraith Parts Wanted 1 03-23-2004 04:50 PM
