86 Turbo Z Sway bar. - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 2Likes
  • 2 Post By Dr. Johny Dodge
post #1 of 11 Old 09-18-2016, 02:01 PM Thread Starter
Level 3 Supporter
89TonaVa's Avatar
My Ride: 89 DaytonShelby TII
Engine: 2.2 Turbo FMIC
What size sway bar is on a 86 Turbo Z?
89TonaVa is offline
post #2 of 11 Old 09-18-2016, 04:56 PM
My Ride: 86 Daytona Turbo Z
Re: 86 Turbo Z Sway bar.
I think 1 1/8 for the Turbo Z and 1 1/4 with the C/S package.
Marc is offline
post #3 of 11 Old 09-18-2016, 05:04 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
and one from an 87 shelby z is the same bar as in the turbo z cs
-so the cs bar really isn't hard to find if you want to upgrade the base turbo z bar
EvilcowRoland and 89TonaVa like this.
Dr. Johny Dodge is offline
post #4 of 11 Old 09-18-2016, 07:57 PM Thread Starter
Level 3 Supporter
89TonaVa's Avatar
Glad you posted this before I ordered my sway bar bushings. I have a donor 88 CS in back yard. Would that still be an 1 1/4 ?
89TonaVa is offline
post #5 of 11 Old 09-18-2016, 08:01 PM Thread Starter
Level 3 Supporter
89TonaVa's Avatar
I might even install rear axle and go four wheel disk. But that's at a latter date and for the thread Im going to start freshening the new to me 86.
89TonaVa is offline
post #6 of 11 Old 09-18-2016, 08:24 PM
Super Moderator
86 cs , 87/8 shelby z & cs and 89 daytona shelby and 89 cs should all have the 1 1/4 bar in em
87 shelby only has the hardest rear trailing axle bushings
post #7 of 11 Old 09-18-2016, 08:31 PM Thread Starter
Level 3 Supporter
89TonaVa's Avatar
Cool thanks. Will order 1 1/4 Sway Bar bushing than.
89TonaVa is offline
post #8 of 11 Old 09-19-2016, 04:34 AM
Some of the 1 1/4 sway bars neck down to 1 1/8 in the area were the bushing is. This was to keep the sway bar from moving side to side.
The car's that got the the 1 1/4 sway bar also got a bigger rear bar also. By just putting on a bigger front sway bar will make the car understeer more.
Marc is offline
post #9 of 11 Old 09-19-2016, 06:52 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
All of the 86-90 1 1/4" sway bars neck down at the ends.
87 and 88 ShelbyZ and possibly CS solid rear axles got the solid HARD rubber bushings. If they're solid and round then they should be the hard ones. Do not burn these out to replace with poly bushings. You'll be sorry.
89TonaVA if you go 4 wheel disc find a 89-90 Shelby or Lebaron GTC to grab the setup and Kmember and arms from. The 87-88 stuff sucks.
GLHNSLHT2 is offline
post #10 of 11 Old 09-19-2016, 07:11 PM
I meant to say some of the 1 1/4 bars neck down to 1 1/8 for the inner bushings.
Marc is offline
post #11 of 11 Old 01-08-2017, 08:58 PM
My Ride: CSX/CS/GLHS
Older thread...
But I have both an 86 CS and 87 Shelby Z off the car and they seem to be identical. The middle of the bar measures 1.25" so the two round center sway bar bushings that go under the sub-frame straps should have a 1.25" inner diameter, the end of the sway bar is reduced to 1" so the rectangular bushings that go on the end of the sway bar and are inserted into the lower control arm are a 1" inner diameter rectangular bushing. It's a good idea to clean the bar to shiney metal before the installation and then apply a silicone grease to the inner diameter of the bushing during installation.
ILIKESHELBYS is offline
