Tires For GLH - Page 2 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Transmission, Suspension, Brakes, Tires & Wheels This Dodge forum includes modification, tuning, repair, replacement, identification and restoration of manual and automatic transaxles, shifters, torque converters, flexplates, flywheels, ring gears, axles, and differentials including open, friction, and Q. This forum also includes modification, repair, replacement, identification and restoration of the above parts and how to tune them for better traction and handling. Also includes wheel bearings and hubs, wheel studs and nuts, wheel spacers, and other related items.
post #16 of 20 Old 08-03-2018, 08:55 AM
My Ride: 1986 Omni GLHS
Garage
Re: Tires For GLH
195 60 15 size option the size increases by only 4.9 percent
Sent from my SM-G950U using Tapatalk
ratrace427 is offline
post #17 of 20 Old 08-03-2018, 09:00 AM
Garage
Re: Tires For GLH
Originally Posted by tryingbe View Post
205/55R16 is what I used temporary in my GLH, it rubbed. 205/60R15 should fit fine as it is 8% smaller.
Another option would be finding a A520 with the 3.5FD and swap out the intermediate shaft, ring gear, and differential into your A555.
looks like 205 60 15 will rub if your 205 55 16 rubbed
post #18 of 20 Old 08-03-2018, 09:18 AM
TD is love, TD is life
Re: Tires For GLH
I didn't see the . in front of the 8% :*(
Maybe try a 205/55R15
tryingbe is offline
post #19 of 20 Old 08-03-2018, 09:44 AM
Garage
Re: Tires For GLH
195 60 is taller than 205 55. maybe that would squeeze into the well without issue.
post #20 of 20 Old 08-03-2018, 02:54 PM
Garage
Re: Tires For GLH
I used a calculator on line to determine that I gained approximately 700rpm switching to the 555 from the 3.08 diff 525 from before. if I switched to the 195 60 15 tire size I would reduce the rpm back approximately 160 rpm. these numbers are not considering the 4th gear ratio difference between the two, so it will be closer to 200rpm drop. thinking about the 700 rpm increase upsets me but a 540- 500 rpm increase after bringing the rpm back down with tires isn't as bad.
this is good info for all of us with light weight cars. I think the 195 60 15s might be the best tire size.
anyone have the 195 60 15s installed currently on a "L" body?
