79 Horizon k-frame - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 16 Old 07-06-2019, 07:43 PM Thread Starter
My Ride: 1979 Horizon
Engine: 1.7 I4
Garage
79 Horizon k-frame
Just inquiring about where to buy one? in cant find anything online. or what years and models i could take one from as I am new to the horizon/omni family ! thanks !
ID:	254627   Click image for larger version
ID:	254629   Click image for larger version
Bakeman420 is offline
post #2 of 16 Old 07-07-2019, 08:39 AM
Re: 79 Horizon k-frame
nice car, was this forsale on Kijiji in Ontario last year?
oh man, its got those fender blinkers like big Chryslers have.
Not sure on the interchange between years, hopefully 78 to 90
is the current part cracked or rusted? if its not rust maybe repair the current one.
raccoon1 is offline
post #3 of 16 Old 07-08-2019, 06:30 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII .60/.63 2-piece SRT4 IC SMEC no B/S ;)
the horizon is an "L-body" in Chrysler terminology.
the K frames are L-body specific, and that family includes:
4-doors omni/horizon, 2-door charger/turismo , trucklet scamp/rampage
detobias is offline
post #4 of 16 Old 07-08-2019, 08:24 AM Thread Starter
Engine: 1.7 I4
Garage
I think i can fix it, just want a backup option just in case.
I do have access to a welder and I have decent fabricating ability, is there another subframe/kframe i could modify to fit?
post #5 of 16 Old 07-08-2019, 08:45 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
well I know you can't weld rust .. and that looks pretty rusty
I'm not intimately familiar with the early L body cars like your's but I do know one thing about the crossmembers
until 1984 the manual trans cars had a linkage pivot point on the crossmember for the shift linkage
in '85 this pivot point was moved to the top of the diff on the transmission
so K frames and linkages differ between 84&5
as for the sway bar , control arms or any other differences to my later car from your's . .. I wouldn't know of .. but I would not be surprised if there were some
Dr. Johny Dodge is online now
post #6 of 16 Old 07-08-2019, 09:16 AM
My Ride: 83 Rampage Base Carb
Garage
You might try car-part.com which does a search at various junk yards. Nothing under "frame" but if you do a search for a door, several '79 horizons/omnis pop up. Maybe giving them a call might get you a decent K frame. Nothing to lose...
Good luck!
John83Rampage is online now
post #7 of 16 Old 07-08-2019, 09:50 AM
Super Moderator
also an automatic car crossmember will be slightly different
lacking the mount for the little dog bone bracket between the crossmember and diff found in the manual cars
- though it's a small simple weld on part
post #8 of 16 Old 07-08-2019, 06:28 PM Thread Starter
Engine: 1.7 I4
Garage
Lol, well yes obv you cant weld rust, i meant would it be cost efficient for me to rebuild the affected area, or just to source a used one, which is another problem im having, i cant find a part picture, listing diagram anything on the crossmember.
post #9 of 16 Old 07-08-2019, 09:35 PM
I found one from a 85 Shelby charger in Alberta.
Ed's Auto Salvage Can-AB(Westlock) Request_Quote 1-800-661-9033
raccoon1 is offline
post #10 of 16 Old 07-09-2019, 05:42 AM
it's possible to section ~2" from an EEK K-member, narrowing it to fit the L ;
I would consider that an 'advanced' welding job ..
detobias is offline
post #11 of 16 Old 07-09-2019, 08:17 AM
Super Moderator
I've read it's an inch and a half wider . but regardless the mount points on the eeK crossmember would also need mods to fit the l body
if you added your location O-P then at least you might get an offer from someone close by
which with the size and weight is a good thing
post #12 of 16 Old 07-09-2019, 07:52 PM Thread Starter
Engine: 1.7 I4
Garage
yes sorry I am Near Toronto
post #13 of 16 Old 07-09-2019, 09:13 PM
Super Moderator
it won't help now but I might have one available by next spring ..I'm planing to do those mount mods to install a daytona crossmember in mine
post #14 of 16 Old 07-09-2019, 10:09 PM Thread Starter
Engine: 1.7 I4
Garage
Is there a thread on said mod?
What is an EEK ?
post #15 of 16 Old 07-10-2019, 07:16 AM
Super Moderator
no thread I've seen , I just got some info from a couple of guys who have done it
(over on the TM site)
eek = most everything other than L body or vans
so shadow, K car , all versions, daytonas , le barons (all body types) lancers etc , all use the same front end "math"
