89 csx 1 gear hard shift - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 9 Old 07-28-2019, 11:03 PM Thread Starter
Hello everyone,
My 89 CSX VNT has only 820 original miles and Iím finding it hard to shift from neutral to first gear. Reverse gear, 2nd, 3rd, 4th and 5th is very smooth. Anything I should be looking at?
Dennism3 is offline
post #2 of 9 Old 07-29-2019, 07:51 AM
Level 2 Supporter
Re: 89 csx 1 gear hard shift
Did you adjust the shifter adjustments? Do you have a FSM?
NAJ posted a good write up the other day
I assume the oil level is good?
cables OK? you can disconnect them at the MTX and can you place into gear by hand.
Lets hope you don't have a bent fork or broken fork pad.
chromguy is offline
post #3 of 9 Old 07-29-2019, 08:00 AM Thread Starter
I will look up the post from Naj. What does FSM and MTX stand for?
Dennism3 is offline
post #4 of 9 Old 07-29-2019, 10:22 PM
Level 2 Supporter
Factory Service Manual and Manual Transmission.
chromguy is offline
post #5 of 9 Old 07-29-2019, 10:28 PM
Level 2 Supporter
chromguy is offline
post #6 of 9 Old 07-29-2019, 11:04 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
the oil fill , check level hole in in the end cover of the trans
THAT happens to be behind the plastic splash shield in the driver's front wheel well
- the cover hanging down from the frame towards the front of the area
- probably has a tire rub mark on it from turning right...
Dr. Johny Dodge is offline
post #7 of 9 Old 07-29-2019, 11:06 PM
Super Moderator
if you haven't checked the trans oil level
DO THAT .. it will likely be low
and when it gets real low things lock up & go bang
post #8 of 9 Old 07-29-2019, 11:10 PM
Super Moderator
clutch cable adjuster works by lifting clutch pedal all the way then pressing back down
post #9 of 9 Old 07-29-2019, 11:16 PM
Super Moderator
on top of the trans , at the back there's an A or V ish shaped bracket .. right above the differential portion of the case
the shifter cables are clipped to this bracket - check the cables are secure in the bracket and the clips are fully installed
..they can slip out sometimes .. and fall off too
(smart guy keeps a couple in the glovebox..with a distributor pick up plate ...))
