A413 flexplate install question - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 10 Old 08-23-2019, 01:56 PM Thread Starter
My Ride: 82 rampage
A413 flexplate install: does the flexplate require a backup ring where it mounts to crank? I installed the flexplate with the depressed side to the crank, now there is a clatter that sounds like the starter gear is rubbing the ring gear. I changed starters with same results. Do I have the flexplate on backwards? the plate is new so no bolt marks to check. I need to know as this is a job to pull the trans back out. Thanks
jax-roxy is offline
post #2 of 10 Old 08-23-2019, 04:42 PM
My Ride: 83 Rampage Base Carb
Garage
Re: A413 flexplate install question
Looked in my FSM but didn't see anything on installing the flexplate.
Here's a scan of a cutaway view of the A413:
John83Rampage is online now
post #3 of 10 Old 08-23-2019, 05:51 PM Thread Starter
My Ride: 82 rampage
thanks I have that, can't get much out of that. I did look at some used ones on ebay and it looks like I installed the plate correctly so it may be some other issue. This project is a swap of manual to auto. lot of room for errors. thanks again
jax-roxy is offline
post #4 of 10 Old 08-23-2019, 06:05 PM
Garage
Did you have a bottom dust cover to install? Seems originally mine was loose a bit and made a clatter sound...
post #5 of 10 Old 08-24-2019, 06:47 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII .60/.63 2-piece SRT4 IC SMEC no B/S ;)
hmm..
there is 5222 613 1 PLATE, Crankshaft Bolt Backing which goes under the bolts (kinda like a big 6-combi-washer),
but, no, there isn't sposed to be anything 'tween 'flex plate' and crank ..
detobias is offline
post #6 of 10 Old 08-24-2019, 06:50 AM
there should be upper and lower dust covers,
the 5222 454 1 COVER, Trans. Case Upper installs between the trans and engine so leaving it out could cause starter <-> ring gear issues
detobias is offline
post #7 of 10 Old 08-24-2019, 01:54 PM Thread Starter
My Ride: 82 rampage
thanks; the dust covers are in place, I turned the heads of the converter bolts down I thought they might be hitting the dust covers, I'm still thinking about that. I did not install that backing plate, I don't have one, never even gave it a thought when I bolted the plate on, I whish I had. I am making a spacer to mount on the starter nose leaving room for the starter to center in its mount. That will tell me if it is ring gear contact. Thanks for the response.
jax-roxy is offline
post #8 of 10 Old 08-24-2019, 01:57 PM Thread Starter
My Ride: 82 rampage
I forgot to say, this trans install is in an 82' rampage. not much room to fit everything in.
jax-roxy is offline
post #9 of 10 Old 08-25-2019, 04:19 PM
if for some reason you want one of those plates I'll maIL you one for free just pay the ride
detobias is offline
post #10 of 10 Old 08-27-2019, 08:56 PM Thread Starter
My Ride: 82 rampage
detobias, yes I would like to have that part. Thanks pm sent
jax-roxy is offline
