Input on which axles to use for '86 GLHT w/turbo ll and A555 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 4Likes
post #1 of 19 Old 09-02-2019, 07:19 PM Thread Starter
My Ride: 1986 Omni GLHT
Engine: 2.2 T2
I have an '86 GLHT with a T2 and an A555 trans. I removed the drivers side axle and the input to trans is 23 splines. I have not removed the passenger side axle yet. I am thinking that this drivers side axle is the stock axle for the '86 GLHT but I have no way of knowing for sure. Rockauto lists the '86 GLHT and the '87 Omni NA (with high output engine) are nearly identical. What to do? This is what the trans that is in the car looks like. A555, right?[Input on which axles to use for '86 GLHT w/turbo ll and A555-a555-close-up.jpg
oo7Shelby is online now
post #2 of 19 Old 09-03-2019, 12:53 AM
TD is love, TD is life
Re: Input on which axles to use for '86 GLHT w/turbo ll and A555
Order 88-90 n/a Dodge Omni AUTO axles to use for A555, A520, A568, and A523 with a Charger/Omni/Rampage/Scamp/Horizon/other L bodies.
tryingbe is offline
post #3 of 19 Old 09-03-2019, 01:13 AM Thread Starter
Engine: 2.2 T2
Yes, that's what I bought. The problem is the axle I pulled out of the trans is 23 spline. The 88-90 Omni automatic axles are 25 spline. No worky. I searched and researched the forums before I posted here. Confusing, yes? to me any way. I am wondering if whoever put this car together put 23 spline axles where 25 spline should be? Would it even be drivable that way? I had only driven the car 3 miles when I discovered there were serious issues to deal with.
Last edited by oo7Shelby; 09-03-2019 at 01:46 AM. Reason: more info and questions.
post #4 of 19 Old 09-03-2019, 02:28 AM
TD Hardcore User!
What were the serious issues driving with the 23 spline axles??
I forget the spline count but could check possibly tomorrow.
The 1986 axles will slip in a 555 but don't properly engage.
All cars except L bodys went to large spline axles for 1987.
L bodys kept small spline but Automatic only had large spline 1988-90
As Harry mentioned, 1988-90 Automatic only are the axles we all use.
Thanks
Randy
oo7Shelby likes this.
Glhs60 is offline
post #5 of 19 Old 09-03-2019, 02:47 AM Thread Starter
Engine: 2.2 T2
Thanks
Randy
Thanks. Can you confirm by the pic that what I have is an A555, if so, why would it have 23 spline inputs? I did not notice any problems with the running gear, it seemed to shift OK and I did not hear any strange noises. The issues I had were that the distributor was installed wrong and they tried to make it run with an '86 MP turbo computer (it did not run well). They actually did some things right, including swapping the right wires to the AIS from the logic module. Thanks for the help, I am learning.
post #6 of 19 Old 09-03-2019, 05:58 AM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII .60/.63 2-piece SRT4 IC SMEC no B/S ;)
um, whats the trans tag say ?
detobias is offline
post #7 of 19 Old 09-03-2019, 10:04 AM Thread Starter
Engine: 2.2 T2
Um, if there was a trans tag on it, I am quite sure I wouldn't be wasting any ones time trying to figure out what axles to use in it.
post #8 of 19 Old 09-03-2019, 10:18 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
the pic you posted is a 520/555/523/568 simply by virtue of the rounded cast aluminum diff cover
523/568 would have a small bell crank lever midway along the shift selector mechanism box on top the trans
easy as pie to tell apart from the o-e 525 with it's FLAT stamped steel diff cover
Dr. Johny Dodge is offline
post #9 of 19 Old 09-03-2019, 12:40 PM
sry thought the pic yu posted was of the actual trans..
detobias is offline
post #10 of 19 Old 09-03-2019, 03:02 PM Thread Starter
Engine: 2.2 T2
Here is the new 1988 Omni drivers side automatic axle and the one I pulled out of the trans. So apparently I need to use '86 up Omni manual cv axles, correct? So I am guessing the tranny is not a A555.
ID:	255303   Click image for larger version
post #11 of 19 Old 09-03-2019, 04:00 PM
Super Moderator
1 525 small spline trans first with flat steel diff cover
2 520/555/523/568 large spline with round cast diff cover this particular one being a 523 or 568
note the different tag location from earlier 555 pic
ID:	255309   Click image for larger version
post #12 of 19 Old 09-03-2019, 04:13 PM
TD Hardcore User!
As mentioned, check your diff cover, located between the axle retainers.
Small spline 525 has a flat stamped steel cover.
Sure seems like you have the small spline unit.
Manual L body axles interchange from 1981-1990 EG: APWI CH8029
Originally GLH-T had an intermediate shaft assembly so both sides take the same axle.
Many ditch the int shaft and use the long 81-90 on the right side. EG: APWI CH8030
Examples are from Rock Auto.
Thanks
Randy
Glhs60 is offline
post #13 of 19 Old 09-03-2019, 08:02 PM Thread Starter
Engine: 2.2 T2
Thanks
Randy
Found it. These are pics of the actual Car and transmission.
ID:	255315   Click image for larger version
ID:	255317   Click image for larger version
ID:	255319   Click image for larger version
ID:	255321   Click image for larger version
post #14 of 19 Old 09-03-2019, 08:46 PM Thread Starter
Engine: 2.2 T2
I owe you a brewski.
post #15 of 19 Old 09-04-2019, 08:17 AM
Level 4 Supporter
Buy axles for an 86 GLH Turbo. Itíll be the same as an NA Omni axle because no manufacturer is making a specific axle for FWD Mopars any more.
Try pulling the passenger side axle before you order. The axle on that side tends to get stuck in the jack shaft. If its stuck, you can order a longer NA axle.
ajakeski is offline
