'87 Daytona Trackday Build - Page 3 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Project Log Post your project logs here
post #31 of 45 Old 09-10-2016, 03:58 PM
My Ride: GLHS 958
Engine: 2.2 Turbo II
Re: '87 Daytona Trackday Build
Looking back again, nothing but impeccable comes to mind to describe your work!
INSATANSSEAT is offline
post #32 of 45 Old 02-18-2017, 09:35 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
I finally managed to get the hood strut setup completed. Here's the link to the thread:
https://www.turbododge.com/forums/f32...e-upgrade.html
LaserDad is offline
post #33 of 45 Old 02-18-2017, 10:13 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
I'm also working on fitting my Eastwood TriFlow radiator in place. I bought the Ford/Chrysler 19x26", which is 2" higher than the original Laser radiator.
Tri-Flow Radiators - NO MORE OVERHEATING!
Being a track day car, I plan to only use water, for coolant, so the thicker core, and the tri-flow design, should really help keep the coolant temp under control.
I plan to run a reverse coolant setup. Since I can't raise the radiator, I'll have to lower it. This requires setting it closer to the engine. The down side is that I will have to redesign the front motor mount.
I had to cut away the lower radiator mounts.
This won't leave much room for the front motor mount, but I'm sure I can come up with something.
Since I plan to keep the AC condenser, I'll have to add shrouding.
The key reference starts at the radiator cap.
This area will need to be opened up for the intercooler piping.
LaserDad is offline
post #34 of 45 Old 02-19-2017, 07:20 AM
edg
Garrett Booster
My Ride: is 250 lexus
Why only water doesn't it boil quicker than coolant, just curious and there's the rust to contend with. Regards. Errol.
edg is offline
post #35 of 45 Old 02-19-2017, 07:35 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
Most tracks don't like anti-freeze because it's hard to clean up. I guess drag strips are the same way.
LaserDad is offline
post #36 of 45 Old 02-20-2017, 08:37 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
Since I have so many aluminum parts, that require welding, I have decided to invest in a TIG welder. Previously, I have had to take parts to various welders, only to get them back oriented differently than I wanted, or wait a couple weeks.
I found this TIG welder on Eastwood's site:
Eastwood TIG200 AC/DC Welder
It had good reviews, works off both 120 and 240v, and was priced at $700. I was able to learn how to MIG weld, from YouTube. Hopefully, I can learn to TIG weld.
LaserDad is offline
post #37 of 45 Old 02-21-2017, 11:26 AM
edg
Garrett Booster
How difficult can it be, the things I've seen u do, wish I must say are quite amazing using the tig is a piece a cake. I learned on a mig welder and I can say that my welds have improved the more I use the machine, before I bought the machine one welder told me just practice it'll come, so my friend fear not it will come. Regards .Errol
edg is offline
post #38 of 45 Old 02-21-2017, 05:58 PM
Garage
loves reading this story. puts faith in me that I can fix the exact amount of rust in the exact same spots on my 86 turbo Z. thanks
mikes86turboz48 is offline
post #39 of 45 Old 02-21-2017, 08:37 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
As I stated before, once I started learning how to weld, my grinding skills really improved.
I do wish that I knew then, what I know now. I have so many burn scars, that could have been avoided.
LaserDad is offline
post #40 of 45 Old 02-21-2017, 10:52 PM
edg
Garrett Booster
Sorry but that comes with the territory and u're most welcome. Regards. Errol.
edg is offline
post #41 of 45 Old 12-27-2017, 09:30 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
I'm going to try and post the missing pics, since PhotoBucket went dark. I'll put down the post# and the pics that were in that post.
Post#1
LaserDad is offline
post #42 of 45 Old 12-27-2017, 09:52 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
Post#2
LaserDad is offline
post #43 of 45 Old 12-27-2017, 09:54 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
Post# 3
My fingers after being sewn up.
LaserDad is offline
post #44 of 45 Old 12-27-2017, 10:03 PM Thread Starter
Level 1 Supporter
LaserDad's Avatar
My Ride: 86 Laser
Engine: 2.2L T2
Post# 7
It was a mess.
LaserDad is offline
post #45 of 45 Old 12-28-2017, 02:36 PM
edg
Garrett Booster
Darn it that must have hurt.
edg is offline
