1986 Turbo Z: Whats involved going from digital to analog dash? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #1 of 6 Old 10-26-2016, 05:36 PM Thread Starter
My Ride: CSX/CS/GLHS
Seriously considering swapping the digital dash for a good, always works analog dash in my Turbo Z. I don't yet have a digital dash to compare to the digital but maybe someone can share their expertise.
Are the wiring connectors the same or do I need to get the connectors off the donor car also?
Is there a speedo cable involved that will need to be added to my car?
How about the cruise control?
I see from the parts book that the dash cluster bezel is not the same for digital and analog dash clusters
4220 307 w/o Electronic Cluster, w/Message Center
4312 360 w/Electronic Cluster and Message Center
Any tips or experience shares would be appreciated.
ILIKESHELBYS is offline
post #2 of 6 Old 10-26-2016, 08:14 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
Re: 1986 Turbo Z: Whats involved going from digital to analog dash?
the trim bezel for the digital dash has a shroud on the back of it that extends inword towards the top of the digital cluster
the 84-6 digital cluster having a flat plastic face with no lens
the analog cluster it;s self extends outward towards the trim bezel and does not need the shroud as the shroud is a part of the body shape of the analog cluster with an angled outward at the top , clear plastic lens
so the trim bezel changes..
now , the 87-9 stuff is different yet again
granted the trim bezel is flat without the shroud , but , it's flat for both style second generation clusters
but wait .. there's one more thing
the 87-9 trim bezel differs at the left side where the headlamp switch is
the two openings at the left side of the 87-9 cluster won't match up if swaped into an 86 .. without changing the black plactic headlamp switch surround plate
(it just clips on)
so a swap to a newer cluster needs the cluster , either / or and the trim bezel & headlamp switch surround
Dr. Johny Dodge is offline
post #3 of 6 Old 10-26-2016, 08:24 PM Thread Starter
Thanks Johny, I would be going with an 85/86 style cluster. So except for the face-plate/bezel and having the correct analog cluster to match your headlight switch, is it a straight forward plug-n-play, remove digital dash and face-plate and install analog dash with appropriate analog face-plate?
Of course I realize I will need the connectors off the donor car and need to do some wiring...
Name:	analog cluster.png
ID:	212137   Click image for larger version
Name:	digital cluster.png
post #4 of 6 Old 10-26-2016, 08:33 PM
Super Moderator
ah hell no
post #5 of 6 Old 10-26-2016, 08:35 PM
Super Moderator
ya still have to swap the pigtails for the cluster plugs
good news is the digital car is going to have a couple of wires you won't end up needing
the same ones you would have to hunt down if swapping a digital cluster into an analog car
no worries on those though , just tape em over as they're unneeded
post #6 of 6 Old 10-26-2016, 08:36 PM
Super Moderator
87-9 the plugs are different for everything on anything.. 'cept the headlamp switch
