85 Turbo Z Turn Signals and Brake Lights Do Not Work - Page 2 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #16 of 54 Old 10-17-2019, 02:34 PM
My Ride: Chrysler lebaron 3.0
Re: 85 Turbo Z Turn Signals and Brake Lights Do Not Work
85 Turbo Z Turn Signals and Brake Lights Do Not Work-6cc55b35-0f9b-4aa9-95ea-7ac07753e1cb.jpg
this is the one
ID:	255815   Click image for larger version
laurp is offline
post #17 of 54 Old 10-17-2019, 04:51 PM
Just A Guy
NAJ's Avatar
The part # on your flasher is not a good part # anywhere, since it was "Made In Germany" I assume it is probably a foreign replacement.
According to my research and going by the numbers located next to each terminal your flasher is the same flasher as mine with a different part #.
According to the Sylvania (Novita) website which explains what the numbers mean, there is an aftermarket replacement, that would be a Novita EP26.
(I learned something new)
SYLVANIA/NOVITA WEBSITE
Flasher Quick Reference | Novita Technologies
ROCK AUTO
https://www.rockauto.com/en/moreinfo...sn=254&jsn=254
Jan
1990 Daytona Shelby VNT
post #18 of 54 Old 10-18-2019, 03:09 AM
Wow NAJ,
you're a living database!!
thank you so much.
laurp is offline
post #19 of 54 Old 10-18-2019, 09:20 AM
Just A Guy
NAJ's Avatar
Let me know if the new flasher fixes your hazard light issue.
post #20 of 54 Old 10-18-2019, 05:34 PM
yes, i will do that.
perhaps another advise? Where to buy refurbished BCM, you know that?
i receive the new flasher on monday already.
laurp is offline
post #21 of 54 Old 10-19-2019, 07:19 AM
Just A Guy
NAJ's Avatar
I can look for you on Monday.
What is the part # on yours or is it a Base or Premium (w/electronic cluster) BCM?
post #22 of 54 Old 10-19-2019, 08:22 PM
1990 Chrysler Le Baron 3.0 Cabriolet Specifications
VINnr: 1C3BJ4531LG473146
Body Controller, (Base) Stamped 4503112
however, i swapped from analog to digital a few years ago and to do that a premium BCM was required.
i can not find a number on my BCM, but i believe there was a number range 4020 in it orso.
is this helpfull?
laurp is offline
post #23 of 54 Old 10-21-2019, 09:36 AM
Just A Guy
NAJ's Avatar
The part # for a 90 Premium BCM is 4503020.
Unfortunately I cannot find any online, I did find one listing for a refurbished BCM but it is Extremely pricey.
https://www.autoecmstore.com/products/4503020
My suggestion would be to open a thread in the "Parts Wanted" section.
post #24 of 54 Old 10-22-2019, 02:15 AM
yes, you find the rightone.
i received the flasher yesterday and try to install it today.
also i try to get an bcm trough this site.
laurp is offline
post #25 of 54 Old 10-22-2019, 09:56 AM
well, the flasher won't work.
the turnlights are working but not the hazardlights.
the relay is also shorter then the accisting one.
i took the the relay from the donor cat, which is exactly the same blue one, but that does not work also.
now i start thinking about a loose wiring orso.
fuses are okay.
i keep looking and posting back to you.
laurp is offline
post #26 of 54 Old 10-22-2019, 10:15 AM
Just A Guy
NAJ's Avatar
There are two power feeds into the Dual Function (Hazard/Cancellation) Switch.
BK/PK wire from fuse #6
BK/WT wire from fuse #28.
The solid BK wire is ground.
Here is the Dual Function Switch test for the Hazards.
post #27 of 54 Old 10-24-2019, 05:14 AM
dual function test where okay.
which one do you mean with black solid ground wire
laurp is offline
post #28 of 54 Old 10-24-2019, 09:41 AM
Just A Guy
NAJ's Avatar
The pinout for the Hazard/Cancellation switch is at the top right.
Circuits L05 and L09 are Power in from Fuses 5 and 28.
Circuit Z01 is Ground.
post #29 of 54 Old 10-24-2019, 10:03 AM
okay, in that case, i have ground aswell as power on the switch on the cavitys.
i replaced the switch just to be sure with a spareone from the donor car, a working switch.
also tried 3 different relays.
fuse are okay
laurp is offline
post #30 of 54 Old 10-24-2019, 10:04 AM
is there a way i can hotwire on the switch?
laurp is offline
Tags
brake lights , turbo z , turn signal
