91 Shadow speedo off +20mph - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #1 of 5 Old 05-16-2019, 10:26 PM Thread Starter
background: Had a bad connection at the vss and speedo would peg the stop at 140mph for a few seconds when cold at takeoff.
Cleaned connections and threw in a different vss too. Now when the car is off, the speedo sits at 20mph. When I drive it, it reads consistently 20mph over my actual speed. Did I bend my speedo needle axle? Can I just pull the cover and push the speedo needle back down to zero?
DUGZSHELBY is offline
post #2 of 5 Old 05-17-2019, 01:29 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
Re: 91 Shadow speedo off +20mph
this is gonna be bust or win
possiably the shaft turned inside the hub of the pointer
so pull the pointer off the shaft , and reinstall on shaft in the correct position
cycle the kye once before you go to put the pointer back on the shaft - it might not be at "zero" after you yank the pointer off so the key should set it right even without the pointer
but be carefull
that pointer HAS to come straight off of the shaft
the shaft is like a needle and it snaps off really easy if you bend it sideways
get a finger tip tight in on either side of the pointer hub with the nails against the gauge face and "lift" the pointer away from the gauge face
use your finger tips like levers to pry the pointer off
don't try to pluck it off the shaft with a thumb and finger
this gives a more steady feel and lift & helps prevent breaking the shaft
Dr. Johny Dodge is offline
post #3 of 5 Old 05-17-2019, 08:26 AM
Just A Guy
NAJ's Avatar
Remove the cluster/cluster mask to gain access to the speedo needle.
Watch this video and it will show you how to remove and replace the speedo needle properly.
The needle has stops at 0 so it will be placed properly.
Odometer Gears
post #4 of 5 Old 05-17-2019, 10:40 PM Thread Starter
Hey thanks A LOT for the info guys!
post #5 of 5 Old 05-22-2019, 03:14 PM Thread Starter
Update: Pulled cluster and gently pushed speedo needle back down to zero. Works great now
Similar Threads
Thread Thread Starter Forum Replies Last Post
160mph speedo in a 140mph speedo car TurboDodge Turbo Dodge Help 3 11-14-2011 02:56 AM
Car shakes badly when accelerating over 20mph donutdan4114 Turbo Dodge Help 7 06-28-2009 08:55 PM
Vibration at 15-20mph contraption22 2.4l Turbo 17 10-15-2005 10:27 PM
won't go over 20mph brianxj99 Turbo Dodge Help 17 09-12-2005 09:33 PM
91 Shadow ES 125 MPH speedo problems 84unturbo Engine Management, Fuel, Spark, EGTs, and Air/Fuel Ratios 0 12-25-2004 07:36 PM
