Need O2 sensor wiring schematic for 89 Shelby CSX - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #1 of 12 Old 09-10-2013, 10:04 PM Thread Starter
Permanently banned
My Ride: CSX/CS/GLHS
Getting code 21, already replaced the O2 sensor. Initial wiring check shows no broken wires.
ILIKESHELBYS is offline
post #2 of 12 Old 09-10-2013, 10:35 PM
Authorized TD Vendor
Re: Need O2 sensor wiring schematic for 89 Shelby CSX
did you use a mopar or ntk sensor?
glhs727 is offline
post #3 of 12 Old 09-10-2013, 11:11 PM
Meow!!
Turbomini's Avatar
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 216
ok i can give you a small run down. but its really general, the grey is ground and the black is the signal wire to comp, the 2 white wires are the heaters if memory serves me right i'll go make sure on my charger which i wired up for 4 wire 02
Turbomini is offline
post #4 of 12 Old 09-10-2013, 11:32 PM
Meow!!
Turbomini's Avatar
Engine: 2.2L TII
Images: 216
edit my bad i should of walked out first :( the 2 whites are grounds the grey is power,
post #5 of 12 Old 09-10-2013, 11:54 PM Thread Starter
Permanently banned
glhs727/Cindy: It's new NTK unit came per wired with proper connector on it, but I did not check the connector to confirm the wires were in proper order nor did I check the other end for bent or pushed in pins...my bad.
Turbomini: Thanks for the wiring colors, that's a start.
post #6 of 12 Old 09-11-2013, 05:33 AM
Just A Guy
NAJ's Avatar
If you still need it I can send you the Code 21 diagnostics tonight.
post #7 of 12 Old 09-11-2013, 08:38 AM Thread Starter
Permanently banned
Jan, yes still needed for sure. Its an 89 CSX/VNT car. Thank you very much for that...
post #8 of 12 Old 09-11-2013, 01:33 PM Thread Starter
Permanently banned
Wednesday bump
post #9 of 12 Old 09-11-2013, 03:47 PM Thread Starter
Permanently banned
Should the power wire have 12 volts present when engine started cold?
With key off both white ground wires good to ground.
with key on engine running 1 ground wire good other no longer grounded.
volts coming out of disconnected sensor black wire start cold at .01v and climbed to .2 volts within 1-2 minutes of running
little or no volts on blk/blu wire from controller when started cold engine.
post #10 of 12 Old 09-11-2013, 06:58 PM
Just A Guy
NAJ's Avatar
Here are the diagnostics from the 90 VNT FSM.
Only difference will be the controller cavities since 89 is a SMEC and 90 is a SBEC.
There are also 2 definitions for Code 21..
1)Oxygen Sensor Signal
2)Oxygen Sensor Shorted High
Only a scanner will give you the true definition
89 O2 Wiring to SMEC(All in 60 Pin Connector)
1)BK/DG Cavity #23 O2 Signal
2)DG/BK Power Feed from ASD.
Wire to O2 Heater is spliced in harness where wire is also spliced for + coil.
3)BK Cavity #5 Signal Ground
4)BK/LB Cavity #4 Sensor Ground
Jan
1990 Daytona Shelby VNT
post #11 of 12 Old 09-12-2013, 10:54 AM Thread Starter
Permanently banned
Thank you Jan/NAJ. I will put it to good use.
post #12 of 12 Old 09-12-2013, 12:54 PM Thread Starter
Permanently banned
Found the problem...the bolt on the 60 pin connector at the SMEC was loose. A wiggle test here w/the engine running quickly revealed the real problem. So...I have a spare used O2 sensor in the glove box now, with a spare HEP! LOL.
It was many years old anyway and probably should have been replaced anyway.
