90+ Speedometer Odometer Gear Replacement - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #1 of 8 Old 09-28-2014, 01:30 PM Thread Starter
TD Extreme User!
My Ride: 90 Daytona Shelby
Images: 12
Garage
NAJ, I apologize for it taking so long to get to this. I figured out how to get it apart without "breaking" it, but the design is rather ridiculous.
Step 1, remove the speed unit from the cluster. I trust we all know how to do that.
Step 2, remove the needle from the unit. You have to twist the needle around to the right until you hit the stop, then gently keep turning it. The needle will start to spin on the axle. At this point, continue to gently turn to the right (clockwise) while also gently pulling up. The needle will slide off the end of the axle.
Step 3, and this is the stupid part, you have to peel off the plastic face plate from the front of the unit. Get a small pick or flat screwdriver and gently pry the black plastic face plate away from the clear acrylic base it's glued to. If you take your time and the plastic isn't too brittle, it should separate. You might need to coax the glue with some heat. I managed to get mine off without breaking it.
Step 4, disconnect the trip reset button from the metal pin. It just clips on.
Step 5, remove the 3 standard-head screws shown in the picture below. They are very small and you need to be gentle taking them out and putting them back so you don't crack the acrylic base.
Once the screws are out, the entire speed driver/odometer assembly will just fall off. Then you can access the screws for the circuit board and replace the gears.
I haven't tried putting it back together yet, so if anyone wants to give it a whirl and report the results of re-attaching the face plate, that would be awesome.
Fun note, the speedo unit in my car is not the original. I had the original (pictured) tucked away in a cabinet because the odometer stopped working. Why? I don't know because the gear is intact. The unit in my car is the later model NipponDenso that I swapped in '04 because it was very close to what the original was showing and I liked the design better. The trip odometer on the ND unit doesn't work because the plastic tabs that hold the trip odometer gears in place broke and the metal bar and gears were laying in the bottom of the unit. All the gears are intact, I just need to replace the reset mechanism which also holds everything in place.
-Brian
90 Daytona Shelby
96 Jeep XJ
EvilcowRoland is offline
post #2 of 8 Old 05-30-2015, 11:36 AM
Just A Guy
NAJ's Avatar
The 89 and older units are shown on a video on www.odometergears.com.
The 90 + has the 3 screws under the faceplate.
post #3 of 8 Old 04-10-2018, 02:33 PM
Level 2 Supporter
gkcooper's Avatar
My Ride: 1992 Daytona R/T
Engine: 2.2 TIII
Garage
Re: 90+ Speedometer Odometer Gear Replacement
Are the aftermarket replacement gears for the trucks the same as ours?
https://www.ebay.com/itm/281885827028
gkcooper is offline
post #4 of 8 Old 04-10-2018, 03:09 PM
TD Extreme User!
My Ride: '88 Shelby Z TII
I've known how to disassemble the 90+ speedos for a long time. It's putting them back together that is more difficult. I don't know what adhesive to use for the gauge face that won't show through, melt the plastic, or cause the backlighting to be funky...all without it peeling back off over time.
Reaper1 is offline
post #5 of 8 Old 04-10-2018, 03:33 PM
Level 2 Supporter
gkcooper's Avatar
Engine: 2.2 TIII
Garage
How about something like this 8.5x11 adhesive sheet:
https://www.amazon.com/Elizabeth-Cra...70_&dpSrc=srch
So, do you think the gears are the same?
gkcooper is offline
post #6 of 8 Old 04-10-2018, 03:35 PM
Level 2 Supporter
gkcooper's Avatar
Engine: 2.2 TIII
Garage
Or these: https://www.amazon.com/Scor-Pal-Scor...W1EB2QEDD0A2WT
gkcooper is offline
post #7 of 8 Old 04-10-2018, 07:30 PM
Just A Guy
NAJ's Avatar
IDK if they are the same.
Here is a link to the site.
Odometer Gears - WELCOME
post #8 of 8 Old 04-11-2018, 02:21 PM
TD Extreme User!
I am 99.99% sure they are the same.
Reaper1 is offline
