T1 piston set ! - Page 2 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts Wanted Post the turbo dodge parts you are looking for here. TD-specific items only.
 2Likes
post #16 of 24 Old 03-03-2017, 10:57 AM Thread Starter
Yes I have the 287 bathtub head and this is what was in the engine it was running great for 3 years
omni85 is offline
post #17 of 24 Old 03-03-2017, 11:06 AM
My Ride: CSX/CS/GLHS
Re: T1 piston set !
87-90 Turbo 2.2 Turbo Intercooled piston made by Mahle, TI looks the same except for slightly different skirt. The good news is it's only flat/broken on one side.
83scamp likes this.
ILIKESHELBYS is offline
post #18 of 24 Old 03-03-2017, 11:22 AM
Level 1 Supporter
83scamp's Avatar
My Ride: 83 Scamp GT
Re: T1 piston set !
Those are factory Mahle's, but that is definitely pistons for a swirl head. My guess is somebody put those in because they couldn't find bathtub pistons. Which should be OK, you are just going to have a slightly lower compression ratio, that's all. And your "squish" band is a lot smaller.
83scamp is offline
post #19 of 24 Old 03-03-2017, 11:45 AM Thread Starter
Re: T1 piston set !
perfect so i could get your new pistons fit to the rods i already have and put these babies back in?
omni85 is offline
post #20 of 24 Old 03-03-2017, 12:06 PM
Level 4 Supporter
Re: T1 piston set !
You would have better luck and probably spend less money looking for a decent shortblock to swap in for the time being.
ajakeski is offline
post #21 of 24 Old 03-03-2017, 12:09 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
Re: T1 piston set !
Originally Posted by 4Daytonas View Post
Check my ad I have a NEW set of press pin pistons for sale. They are 86 up swirl but everyone says not to switch. I have swirl pistons in ALL my 287 head engines and they work great!. My 2.5 has a bathtub head and I run 23 lbs boost with NO problems since I built it several years ago.They actually LOWER the compression a small amount so that's not a bad thing in a boosted engine.I also have a used set of T2 pistons for sale. Check my ad in parts for sale.
the press pin 86 swerl head , larger dish pistons will work just fine with the earlier 85 bath tub style combustion chambers and the 85 press pin rods
I've personally done it with no issues ... AND they were cast aftermarket pistons , though they were made pre hyperpuke as in 86
- and I ran 'em at 12#'s of boost without issue
Dr. Johny Dodge is offline
post #22 of 24 Old 03-03-2017, 12:13 PM
Super Moderator
Re: T1 piston set !
to add
84-5 , smallest dish
86 medium dish
TII and 89^ 2.5 turbo largest dish with a small edge around the dish - not my favorite design
post #23 of 24 Old 03-04-2017, 04:45 AM
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
Re: T1 piston set !
thanks for the info guys, why does everyone say to change the rod aswell? cant you just put a diffrerent piston back on the same rod?
yes you can just put your old rod on a new-/different piston. My new set is not hyper pistons. and the used ones are Factory T2
4Daytonas is offline
post #24 of 24 Old 03-04-2017, 10:58 PM
My Ride: 85 shelby chrger
Re: T1 piston set !
I have a new set 0f 30 over pistons and 4 good 85 t1 rods with stock pistons also good.
mrmopar247 is offline
