1988 2.5 Water Pump Housing - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts Wanted Post the turbo dodge parts you are looking for here. TD-specific items only.
post #1 of 13 Old 07-15-2018, 05:11 PM Thread Starter
My Ride: 1987 Turbo Buick
Engine: 3.8
Garage
We have the new water pump but the "housing" the the pump bolts to that bolts to the block has a hole in it. Before i just slather it down in JB weld I thought I'd ask to see if anyone had such a piece. and if so what it would take to get it shipped to 76017. Ill see if I can get some pix of it up. It is in an '88 Plymouth Sundance. Not a turbo but I have found the turbo guys work on theirs so they know about needing parts.
Thanks Y'all
Rich
TexasT is offline
post #2 of 13 Old 07-15-2018, 06:39 PM
My Ride: 83 Rampage Base Carb
Garage
Re: 1988 2.5 Water Pump Housing
Welcome to TD!
I ran into the same problem with my 2.2 Housing. It was covered in & out with corrosion when I
took it off. Cleaning it up I discovered a hole about 1/16" where the pump's impeller sits. Reamed
out the hole to bare metal and put JB weld on the inside, smoothing it and when it set up some,
pressed down on the outside to form a "cap".
Hadn't installed it yet but I'm hoping that it'll work!
You might have to go this route if no replacement can be found.
Good luck!
ID:	250655   Click image for larger version
John83Rampage is offline
post #3 of 13 Old 07-15-2018, 07:17 PM Thread Starter
Engine: 3.8
Garage
That is the way I am leaning.
The hole is not too large but the corrosion sure did the interior no favors.
TexasT is offline
post #4 of 13 Old 07-17-2018, 01:00 PM
Garrett Booster
I have a stack of housings let me dig thru them and find the one you need
Sent from my iPhone using Tapatalk
2fast2dodge is offline
post #5 of 13 Old 07-17-2018, 04:15 PM
Garrett Booster
I have the housing, $25 plus shipping from 97213
PM me
post #6 of 13 Old 08-08-2018, 07:51 AM Thread Starter
Engine: 3.8
Garage
Alright, we have the new housing(thanks mr 2fast2dodge), but have run into the next problem. The new to me housing doesn't have a nipple to attach the heater hose to it. This brings me to the conundrum, do I keep searching(Mr Doza, if you have a shipped price on yours let me know), or drill and tap a hole and put in a nipple to attach the heater hose?
Anyone attempted the drill mod or is it just easier to find one and swap it on?
Thanks for the input.
TexasT is offline
post #7 of 13 Old 08-08-2018, 12:47 PM
TD is love, TD is life
Drill and tap always worked for me.
tryingbe is offline
post #8 of 13 Old 08-08-2018, 01:29 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
or a little stroll through the boneyard to find a T that will fit the lower rad hose and provide a location for the heater hose
some newer cars are done like that
adding the heater hose location to the cold side rad tank might actually be easier - if you can solder
rad solder is 30/70 , same as body lead
Dr. Johny Dodge is offline
post #9 of 13 Old 08-10-2018, 07:21 AM
My Ride: 2006 chevy
Rich how is 25 for water pump 20 for shipping lmk
dennis doza is online now
post #10 of 13 Old 08-11-2018, 05:59 AM
My Ride: 2006 chevy
here are some pic
ID:	250967   Click image for larger version
ID:	250969   Click image for larger version
post #11 of 13 Old 08-13-2018, 07:51 PM
Garrett Booster
I have both types of housing rear nipple outlet and bottom exit nipple
Bottom exit is late , 2.2/2.5 reverse rotation
$25 plus shipping
post #12 of 13 Old 08-14-2018, 11:28 AM Thread Starter
Engine: 3.8
Garage
Does the bottom outlet differ significantly? How do I know what style should be on my engine? It had the side out but it is a used car so I don't know what would be correct.
I have a deal working on a down outlet but if that wont work I wouldn't want that. I just have the no out let on there now and the heater hose plugged off. But I'm sure we will want the defrost to work come winter time.
TexasT is offline
post #13 of 13 Old 08-17-2018, 06:00 PM
Garrett Booster
Ok I have bottom out and rear out,
The late model pump housing will work on any year, but be warned, you must use the late model smooth pull because the belt turns the pump reverse rotation- as the early.
The housing scroll will be opposite.on the early and the pilot will be grooved.
I think the 89 is the odd ball pulley bolt spacing is odd.
PM me I can send pics if this site will work!
