Bobble Strut Bracket - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts Wanted Post the turbo dodge parts you are looking for here. TD-specific items only.
post #1 of 14 Old 02-01-2019, 11:47 AM Thread Starter
My Ride: Chrysler LeBaron
Engine: 2.2L Turbo I
Looking for the bracket that bolts to the rear of an A520 transmission for the bobble strut to attach to. Part number 4412041 I believe.
Swapping an auto for a manual transmission and the transmission did not come with this part.
Thanks.
ntrodda is offline
post #2 of 14 Old 02-01-2019, 04:11 PM
My Ride: !989 Lebaron GTC
Engine: 2.2L Turbo II
Re: Bobble Strut Bracket
I'm wondering if this is what you are looking for.
steel engine mount bracket
The strut itself can be bought from the same company.
bobble strut engine mount
89BaronGTC is offline
post #3 of 14 Old 02-01-2019, 04:28 PM Thread Starter
That bracket goes on the frame. I'm looking for the bracket that bolts to the transmission.
ntrodda is offline
post #4 of 14 Old 02-05-2019, 06:02 PM
My Ride: 1984 Chrysler Laser
Hello,
What year is your car?
laser_doogie is offline
post #5 of 14 Old 02-06-2019, 04:02 AM Thread Starter
1987.
ntrodda is offline
post #6 of 14 Old 02-06-2019, 12:04 PM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
there's the factory good for nothing shock absorber style ones
there's the adjustable solid ones from the vendors
and there's the '87 K car ones
those look like the dog bone style found in the L body cars
they use a unique bracket to mount on the trans (520-568)as they have a horizontal bolt rather than the vertical threaded post on the shock style ones
Dr. Johny Dodge is offline
post #7 of 14 Old 05-13-2019, 10:48 PM
My Ride: 1986 Dodge Omni GLH
Engine: Turbo II
Hey Dr. Dodge, I have a 568 going in an L-body. I'll be using cables. I was just trying to hook up the rear bobble mount tonight, but I don't think I have what I need. I have the stock shock absorber style I know, but what is the '87 K-car bracket that mounts to the transmission? what does it look like? I want to just run a bolt through the ears of the k-frame side of the mount. I've never done it before.
Inferno1zx is offline
post #8 of 14 Old 05-13-2019, 11:51 PM
Super Moderator
the bracket I referred to attaches the bobble bracket to the trans , not the K frame
the bottom of the bobble bracket should fit between the tabs on the K frame .. until you try to put a 520-568 trans into the car
it will come down right beside one of the tabs - towards the outside of the tab , not between like it should
this is solved with welding on another tab ... OR finding a short piece of steel tubing to go between the tabs and a longer bolt
if you can attach your bobble bracket to the trans as you are you're not missing anything
the only thing that's supposed to be needed to attach to the K frame is the nut and bolt
but the trans swap affects that slightly
post #9 of 14 Old 05-14-2019, 05:21 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
Most common style.
then the hard to find, bad ass, way more clearance style. Dr JD says he finds them on k-cars. Never seen one there but I have found 2 on 88 5spd caravans.
GLHNSLHT2 is offline
post #10 of 14 Old 05-14-2019, 05:45 PM
Super Moderator
yep .. K car 87 520 is what I pulled mine from
it was also a really nice minty clean car thus the decision to pull the trans from it
- so I doubt it had been replaced (mid early 90's)
probably the only 5spd 87^ K car I ever saw in the yards so I can't say more than what I found ..
I had the console and shifter from it saved too in case the K wagon thing ever happened
some really early daytonas and lazers back the end of 83 / early 84 also got dog bones on their 525's
post #11 of 14 Old 05-20-2019, 03:05 PM
Hybrid Booster
Long before I ever knew the second style existed, I cut up and re-welded the common style. Easy to do. Required if using TBI manifold.
4 L-bodies is online now
post #12 of 14 Old 05-20-2019, 03:38 PM
Super Moderator
yeah I saved the one in my blue tz when I hadda scrap it as I knew I'd never find another
never really paid a lot of attn to it I just bolted it on but looking at the pic above , yeah , much beefier
the shock thing is a joke and always was
post #13 of 14 Old 05-20-2019, 05:40 PM
Legendary Driver
GLHNSLHT2's Avatar
Not all of us have your fab skills though Todd :)
My SDS and shifter cable are more in the way than the bobble strut bracket is though :(
post #14 of 14 Old 05-29-2019, 05:19 PM
Level 4 Supporter
$40 each
ajakeski is offline
