Suspension wtb, power steering conversion for 82 L body - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Parts Wanted Post the turbo dodge parts you are looking for here. TD-specific items only.
post #1 of 10 Old 06-15-2019, 09:52 AM Thread Starter
My Ride: 82 rampage
HI: I'm new to this forum, is there a sub forum to place parts wanted ads? I have a 82 rampage, I'm looking for any or all parts to convert manual to power steering. my rampage has only one belt for alternator. thanks
jax-roxy is offline
post #2 of 10 Old 06-15-2019, 10:08 AM
My Ride: 83 Rampage Base Carb
Garage
re: wtb, power steering conversion for 82 L body
In the upper left by "HOME" go to Forums, let the menu drop down, then to Buy Sell Trade then to right to Parts Wanted.
Does your Rampage have AC? Check the crankshaft pulley. With AC you should have 3 spots for belts. For power steering you'll need the pump, bracket, lines to steering rack and of course the rack & pinion assembly. There are 2 types of steering racks: Saginaw & TRW. Each rack has different lines but use the same pump... The PS rack will bolt onto the K Frame just like the manual.
If your crankshaft pulley only has one spot for the belt (alt/water pump) the of course you'll need a different pulley.
You can source the parts from any L Body...
John83Rampage is offline
post #3 of 10 Old 06-15-2019, 10:52 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
I can't remember off hand as it's been thirty years since I did this but you may well need the flex joint that joins the steering column and rack
the one for the power rack MIGHT be different ..
hopefully someone will know
on your crank pulley , check the back side of it for another smaller unused groove
it might just have the pulley you need
though being an early year car it may not..
Dr. Johny Dodge is offline
post #4 of 10 Old 06-15-2019, 10:55 AM
Super Moderator
Re: wtb, power steering conversion for 82 L body
title modified and thread moved to wanted parts section
post #5 of 10 Old 06-15-2019, 11:33 AM
Garage
Just checked the '82 FPM. Yes, different couplings/flex joint for manual & power...
post #6 of 10 Old 06-16-2019, 08:44 AM Thread Starter
My Ride: 82 rampage
thanks: yes it does have the dual pulley. I would like to find the P/S pump and mount brackets. rock auto has rebuilt racks
jax-roxy is offline
post #7 of 10 Old 06-16-2019, 10:02 AM
Garage
They also have the pumps & hoses but you'll have to absorb the core charge. You could roll the dice and look at eBay.
The issue is the main bracket & the small adjusting bracket...
post #8 of 10 Old 06-16-2019, 04:43 PM
Super Moderator
and the bolts
and the nut(S) ,..
a complete pump with brackets , hardware , lines and even the belt would be nice all pulled from one car
still not sure but you may also need the clamp brackets for the power rack to attach to the crossmember
(thinking I remember at least one was different ???)
along with the swivel joint
then you even have CORRECT lines to take to the store to match with new ones
that saves a few ,..trips ..sometimes
post #9 of 10 Old 06-16-2019, 08:34 PM
TD Extreme User!
My Ride: 2017 Subaru WRX
Engine: 2.0l Boxer Turbo
Too bad you are in CA. I have the power steering stuff from an 84 Rampage and all in good condition when pulled. I actually did the reverse swap as I wanted manual steering with my 2.4l Swap.
Once you have everything swapped out, don't throw the parts away as there are always people looking for a good manual rack and couplers from the column to the rack.
If you end up getting a rack and what not though, I do have the couplers that I would be willing to let go for next to nothing.
1983Rampage is offline
post #10 of 10 Old 06-16-2019, 09:24 PM Thread Starter
My Ride: 82 rampage
HI: I will take what ever I can get, all or part, if you wanted to you could ship it fedx or ups freight or I would take the pump and brackets or any part you would like to sell. TX is not that far. let me know. Thanks Bill
jax-roxy is offline
