'83 Rampage Turn Signal Housings - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 14 Old 08-31-2019, 12:05 AM Thread Starter
My Ride: 83 Dodge Rampage
Engine: 2.5 153cc
Garage
So my 1983 Rampage had a solid amber turn signal, one being broken. I came across another 1983 at a Pick N Pull and found a different style turn signal on it. Before I pulled them, they appeared to fit nicely and be contoured to the front bumper. However, upon putting them in mine, they do not seem to fit at all the same. Does anyone know more about the differences? I'll list them for the cost of shipping once I understand what they should fit.
The broken ones on my truck:
The ones that fit the other '83 rampage, but not mine as you can see:
The backs are identical, but you can see the fronts are not:
Wes Henderson is offline
post #2 of 14 Old 08-31-2019, 12:40 AM
Super Moderator
Dr. Johny Dodge's Avatar
My Ride: 87 Shelby Charger
Re: '83 Rampage Turn Signal Housings
did you possibly grab a turn signal lens from a 4 lamp front end ?
I think they're smaller
Dr. Johny Dodge is offline
post #3 of 14 Old 08-31-2019, 12:45 AM Thread Starter
Engine: 2.5 153cc
Garage
Nope. That's the strange part. It was a two-headlight 1983 just like mine.
post #4 of 14 Old 08-31-2019, 02:35 PM
TD Hardcore User!
My Ride: 1992 IROC R/T
Engine: 16V
Images: 10
what is the lettering on the lenses and on the backside of the lamps?
marty mopar is online now
post #5 of 14 Old 08-31-2019, 02:50 PM Thread Starter
Engine: 2.5 153cc
Garage
The back halves are the same, "5207594/95" for right and left respectively. The lenses are "SAE IP 79M" and "SAE IP 79Z". The 79M fits my rampage. The 79Z is the smaller one with black on the lens.
post #6 of 14 Old 08-31-2019, 06:09 PM
I didn't check the 1983 parts manual, but I know from the 1984 parts manual that the 1984 Dodge Rampage used a front turn signal housing that was different from every other 1984 model.
Meek is offline
post #7 of 14 Old 09-01-2019, 01:29 PM
TD Hardcore User!
Engine: 16V
Images: 10
M= Horizon
Z= Omni
M,Z= L Body
post #8 of 14 Old 09-01-2019, 02:00 PM
Super Moderator
often ,the year of the car is cast right into the tail lamp lens
^^ that "79M" may indicate those lenses were for a '79
MAYBE
I think I've noted some difference(s) in the early 2 lamp nose along the bumper rub strip so there may well be other little differences to be found
and a 78-9 nose on an 83 might be hard to note if you don't see the fine detail differences
all 84's got the new for '84 four lamp front end except the shelby chargers
post #9 of 14 Old 09-01-2019, 09:01 PM
TD Hardcore User!
Engine: 16V
Images: 10
parts are often stamped with a date code....especially lenses but may fit more than one year
post #10 of 14 Old 09-03-2019, 02:30 PM Thread Starter
Engine: 2.5 153cc
Garage
M= Horizon
Z= Omni
M,Z= L Body
Yea, I know those from the factory service manual. I was moreso confused by how the others fit another rampage. After some Google-fu, I found where it looks like there are front bumpers with a different lower half. No clue if that was related to a trim option or what.
post #11 of 14 Old 09-03-2019, 04:09 PM
Super Moderator
it's going to be either a model year difference or a dodge plymouth difference as there was that possibility back then too - rampage might differ from scamp (?)
post #12 of 14 Old 09-03-2019, 04:37 PM
My Ride: 83 Rampage Base Carb
Garage
Just went out and looked at the lamps on my '83 Rampage.
They look like the replacements that you got.
I checked the '82 & '83 parts manuals. Lamps (5207568-9) are the same for both years and are indicated for "L Body--28" (Fwd Pickup). Nothing indicates for M nor Z. So should be the same for Rampage or Scamp. These are also the same lamps for the "L Body--24" (2 door).
The parts manuals do not indicate the housing number, only the "Lamp Assy" number as indicated above.
What do you have there Wes !?!?!?!?
John83Rampage is online now
post #13 of 14 Old 09-04-2019, 08:51 PM
TD Hardcore User!
I just checked the lights I recently bought for my 84 thats going to 2 lights.
They are from a 1982 Rampage and have the same #'s as yours.
Except mine have 79 MZ on each one, is one pair of yours M and the other Z??.
My experience is the year date on a lens it's the first year it was used.
Mine look like the ones you bought.
My 1982 bumper rebar is steel, I understand some are aluminum??
Could that be the difference?? Is yours Aluminum??
My 4 light rebar was alum but the bar/lights were definitely different from 2 bar
Thanks
Randy
86 GLH S60
86 GLHS 373
89 Turbo Minivan
83 Rampage Turbo
Glhs60 is offline
post #14 of 14 Old 09-05-2019, 07:33 PM
Garage
Here's a front view of my Rampage when I got it.
As can be seen, it has the rectangular ones...
Name:	Rampage before 8.jpg
