Official Rampage/Scamp Thread - Page 34 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 9Likes
post #496 of 561 Old 03-24-2019, 08:43 PM
My Ride: 83 Rampage Base Carb
Garage
Re: Official Rampage/Scamp Thread
Well now I'm wondering even more! My Rampage was a special order for the GSA. The Corp of Engineers used it somewhere around here, probably around one of the lakes that they manage. When I got my Rampage it didn't have the window trim, carpet on the panel nor the storage tray. There were some sort of electrical junctions attached to the back panel and a switch (like the old headlight high beam switch) in the floor board by the driver's left foot. Maybe these were for emergency lights or some sort of emergency equipment that the Corp used. Someone later put a carpet covered piece of plywood over the panel with 2 speakers installed. All of this I've pulled out now.
Either the Corp took out the trim, carpet & tray or Chrysler built it that way and put the jack instruction decals there on the panel. But if one looks carefully at the decals they ARE for the Rampage Model. So my question still remains on the location of the decals. Hidden underneath carpet? Might be so, where else could they be applied? Surely other Rampages/Scamps had them...
John83Rampage is offline
post #497 of 561 Old 03-25-2019, 09:56 AM
My Ride: Scamp GT
Not this one I think John. With the help of a friend I Intercepted this one as it came into a wrecking Yard in Helena, Mt. on a rollback to be scrapped. My friend was in that yard when it came thru' the gate. Got the original Montana title that waz dated 10/82. that the owner had just signed off in July of 2003. I won't bore you with the whole story but I had it delivered to our home in Chelsea, Mi. 5 weeks later and drove it off the haul trailer, Jer
bigbarneycars is offline
post #498 of 561 Old 03-25-2019, 11:42 AM
Garage
Well the mystery continues. Perhaps the decals weren't a required item on vehicles. Maybe Chrysler had a "dress-up package" option for the back that included the carpet & tray so no decals to waste money. I did notice that the bottom brackets for the tray have no holes drilled for the tray's mounting screws.
Ha! I've got a rare Rampage! Only one with jack instruction decals!
post #499 of 561 Old 03-25-2019, 01:24 PM
My Ride: Scamp GT
I think you just answered your own question John. I'm sure you can figure out where to bore the holes in the mounting tray brackets if the holes are already in the tray? You have one of 40,000+ 'Page's, plus another 4,100 Scamps? Damn, you won't even wanna talk to us regular folks, lol. I'm still hunting for my receipt for the new molding clips to mount the plate under the back glass. 7 of 'um if I remember rite? Jer
post #500 of 561 Old 03-25-2019, 02:43 PM
Garage
Yes, there's 7 of those clips needed. Look like little aliens with antennas! LOL
Now I need help to make a decision: should I put in carpet on the panel or leave the carpet off to show off my decals???
post #501 of 561 Old 04-03-2019, 08:25 AM
Hello, I am not the most car savvy, and I think my egr valve is clogged, I know I need to remove it, and clean it, but I can't find it. Where is it located within the engine bay of the 1983 dodge rampage? Just point me in the general direction, and I'll be fine, I hope to learn more about cars by working on this one, so any direction will help, don't want to take off the wrong thing.
TheTurtleyOne is offline
post #502 of 561 Old 04-03-2019, 08:42 AM
Garage
Welcome to TurboDodge!
The EGR valve is on the exhaust manifold. On the driver's side of the engine bay look underneath the carb which sits on the intake manifold which is over the exhaust manifold. Put plenty of penetrant on the nuts because they're probably rusted on good. Let it soak and soak then carefully try to remove them without breaking the studs. Be patient! You might want to soak them overnight...
Invest in some Service Manuals:
https://www.ebay.com/itm/1983-DODGE-...UAAOSwhlZYslMI
Also there is a Parts Catalog you can download here:
http://www.glmwpg.com/ServiceManuals/83p.PDF
Any issues or problems just let us know.
Good luck!
post #503 of 561 Old 04-03-2019, 04:49 PM
Thank you so much! I'll let you know if it works and give more of a history of my rampage after I fix it.
post #504 of 561 Old 04-03-2019, 08:02 PM
Garage
We're here to help!
Post some pics when you can...
One question that you can help me with: Does your Rampage have carpet on the panel under the back window? If it doesn't, does it have the jack instructions labels? If you look at some of the previous posts you'll see what I'm talking about. Thanks.
Good luck with those rusty nuts & bolts!
post #505 of 561 Old 04-04-2019, 04:47 PM
Didn't see any jacking instructions, the previous owner installed huge speakers and a nylon parts holder thing, but there is still carpet underneath it.
post #506 of 561 Old 04-04-2019, 05:26 PM
Garage
Ok, thanks!
Thought that I'd ask...
Hope that EGR valve is coming along.
Take care!
post #507 of 561 Old 04-05-2019, 01:10 AM
My Ride: 1986 GLH TII
Originally Posted by John83Rampage View Post
There in Ft Worth? They've done tons of construction around there and are still at it. You wouldn't know which way is where now!
Hey, anyone know where to get the clips for the black metal trim that goes outside below the back window? A fellow member sold me the trim piece but I'm needing those clips...
Thanks for any info!
I bought some rear window moulding clips from Altha Fastener back in 2012 for my '84 DC Rampage, the part number is: cp554582, and they are called "82-on Chrysler back panel moulding clip" they were $1.28 each then. I did a quick look on their site, but I couldn't find them, but at least you have a P/N to search...hope this helps.
Chuck
ChucksterGLHT is offline
post #508 of 561 Old 04-05-2019, 08:01 AM
Garage
Chuck
Bigbarneycars gave me the name of that Vendor and gave them a call. Unfortunately they're all out of the clips. The guy called someone else he knew and still no luck.
Thanks for the part number! It'll give me more info for a search.
Take care!
post #509 of 561 Old 04-05-2019, 09:08 AM
My Ride: Scamp GT
'Mornin' All youz 'Lil Trucklet Junkies. FYI for the New Guy TheTurtleyOne. Mother Mopar made a running change on the '83 'Pages/Scamps on the 25th of January 1983 to the HOOD,FENDER, A-PILLER JUNCTION of those 3 parts. If you ever need fender replacements for your '83 you'll need the build date of your Trucklet before you go shopping. BEFORE'S + AFTERS WILL NOT INTERCHANGE. Take your vin # to any Mopar Dealership and have them punch you # into their computer to get your build date. They call me Jer on the internet TTO, 1st names are allowed, and John you've met. Happy Trails Y'all, Jer
post #510 of 561 Old 04-05-2019, 11:59 AM
TD Hardcore User!
I just checked my 84 and it has a jacking instruction label.
Thanks
Randy
Glhs60 is online now
