Anyone know what tool will unscrew the tranny fill plug on 2004 6 spd turbo diesel tranny. It is a female, hexagonal plug. Thanks
Dealer Connect is showing a "square drive" plug.
If it is a "hex" it could either be 14mm that is used in the front differential in the newer Grand Cherokee/Commander or 18mm which is used in the Wrangler manual trans.
Checked Dealer Connect again.
You have an NV5600 Trans.
Chrylser shows the drain being the bottom bolt in the PTO Cover(L/S front of trans case. 6 bolts,have no idea what PTO stands for) and the fill plug(L/S rear of trans case) is a square drive, they do not list a size but if it is a square drive will either be 3/8" or 1/2".
