Anybody out there have a full 11" vented front/rear brake setup from a later GTC or R/T vehicle on their L-body (Charger/Omni)?
I have the rear 11" brake setup figured out (99% bolt-on), but what about the fronts? I know I'll have to use the later knuckle with the bolt-in hubs, but it will need to be modified to work with the L-body strut. Should I measure the thickness of the strut 'leg' on the L-body knuckle and have the later knuckle machined to the same thickness, taking an equal amount off both sides? Any other machining required to make it work?
