Hi Cindy ... just to clear up the sprocket thing a little. There is only one RDTH sprocket (690) that will RET cam timing 4* over the conventional (577) RDTH sprocket.
SQTH to RDTH (557) doesn't change cam timing one bit. Got all the sprockets here and have checked.
I won't go into the roller cam differences except to say that TBI are all basically the same (4* RET ground in .. '88 and '89 2.5l only) and then you have the 89+ turbo roller cam which is unique. That's (2) different stock roller cams total.
People can get some nice top end on a turbo with the 90+TBI cams <--- only because they are probably in better shape, then put 4* RET to it. Performs like the '89 turbo cam then ... but with more duration.
