Will 15x6 195/65R15 fit a 1988 Dodge Aries? Thanks in advance.
Nice set of wheels, having said that, since they are GM wheels, are those 15x6's, or 15x7's?.....the + offset on the GM wheels might be a bit deeper than the Chrysler wheel, hope you don't have caliper clearance concerns, or tire clearance issues with the strut tube. I've tried to (test) mount a set of 15x7 Fiero GT wheels and there were clearance problems.Ok folks. I got me some Beretta GTU wheels, just need to get two more. I couldn't get the other two because it had some weird lug nut on it but anyways I'll get the other two soon enough. They are 205-60-15.Here are a couple of pictures.
Just got em home.
I sanded the Chevy logo off the center caps and sprayed them down with some black textured paint.
Thanks, they are 15x7. The Fiero GT wheels look to be quite a bit deeper than the Beretta GT wheels to me so I shouldn't have any clearance problems. I will test fit one tomorrow to see if there are any clearance issues. Thanks for the tip.:thumb:Nice set of wheels, having said that, since they are GM wheels, are those 15x6's, or 15x7's?.....the + offset on the GM wheels might be a bit deeper than the Chrysler wheel, hope you don't have caliper clearance concerns, or tire clearance issues with the strut tube. I've tried to (test) mount a set of 15x7 Fiero GT wheels and there were clearance problems.
Yes, they stay tucked inside of the lip of the fender but have a a wider and nicer stance compared to the 14" wheel barrow tires I have up there currently. I knew I have seen wheels similar to the Beretta GT ones before on another Chrysler somewhere.They look rather good on your car, they have a sort of *Formal* not *racey* look to them, (they would look good on the New Yorker, but then Chrysler did use a set of NY alloy wheels that are similar to those)....Does the top of the tire/wheel stay tucked inside of the lip of the fender?....
