where is the location of the 1984 dodge daytona turbo z map sensor? if anyone would have pics that would be great. thanks :bang head
On an '84 daytona, the MAP sensor should be located above the logic module, which is located behind the passenger side kick panel in the car.
MY car isn't an 84, but this should clarify the location.
the easy way to it is remove the entire glove box from the dash, Look upwards to the right,It's mounted just below the windshield piller. Its a black box type ( doesn't resemble the 85's thru 87's in appearance ) two phillip screws hold it in place you'll see a Vac line attached with a spliter going to Turbo gauge and a 3 wire connector plugs into it.
Hope this helps you out.:thumb:
