1 - 20 of 63 Posts
Thanks to James and Cindy at FWDPerformance for all the help with my project.
Dyno run in my T3 powered 1986 Daytona.
Aem EMS-4 Stand Alone tuner.
[email protected] [email protected]
26psi with a 60/40 93oct/E85 blend
Stock intake manifold, fuel rail, and exhaust manifold.
Finally able to get some full passes in with the wider sticker drag radials and get my profec spec 2 to control boost.
Car is capable of so much more, but I do not want to push my luck with the stock T3 rods. I have a fully built race motor to go in, this was just a test and tune motor.
Discussion Starter #2
A little history...
I bought this car in 1999 for $500 from the backlot of a kia dealership.
1986 dodge daytona turbo z c/s. Originally a white ext maroon int, turbo i, 5 speed manual trans car. After blowing a hole in the a525 trans housing, trans was upgraded to a heavy duty a568 getrag unit and a spirit r/t stock clutch, boost was also increased to 14psi from the stock 9psi. Car ran very well for about a year. The boost and aggressive driving finally took its toll on the original engine(had 125k on it).
Upgraded to a t2 motor from a 88 shelby z and a new turbo from tu. Car ran like a dream.
After that i bought a spirit r/t. That was it, so much easier to make power with the dohc motor. It had a stock 1991 dohc motor with a custom cal.(set at 20psi), 20 inj., and 3" mb exhaust. This was installed as a test fit/function before paint work was done.
Discussion Starter #12
Upol Raptor Bed Liner goes on thick and hardens like a rock. I coated everything with that stuff, even my toast in the morning:thumb:
Discussion Starter #14
last set for now:dancing:
The dyno graph with the dip is where the tires broke loose on the dyno, scary.
1 - 20 of 63 Posts
