1 - 13 of 13 Posts
We have the new water pump but the "housing" the the pump bolts to that bolts to the block has a hole in it. Before i just slather it down in JB weld I thought I'd ask to see if anyone had such a piece. and if so what it would take to get it shipped to 76017. Ill see if I can get some pix of it up. It is in an '88 Plymouth Sundance. Not a turbo but I have found the turbo guys work on theirs so they know about needing parts.
Thanks Y'all
Rich
Welcome to TD!
I ran into the same problem with my 2.2 Housing. It was covered in & out with corrosion when I
took it off. Cleaning it up I discovered a hole about 1/16" where the pump's impeller sits. Reamed
out the hole to bare metal and put JB weld on the inside, smoothing it and when it set up some,
pressed down on the outside to form a "cap".
Hadn't installed it yet but I'm hoping that it'll work!
You might have to go this route if no replacement can be found.
Good luck!
Alright, we have the new housing(thanks mr 2fast2dodge), but have run into the next problem. The new to me housing doesn't have a nipple to attach the heater hose to it. This brings me to the conundrum, do I keep searching(Mr Doza, if you have a shipped price on yours let me know), or drill and tap a hole and put in a nipple to attach the heater hose?
Anyone attempted the drill mod or is it just easier to find one and swap it on?
Thanks for the input.
or a little stroll through the boneyard to find a T that will fit the lower rad hose and provide a location for the heater hose
some newer cars are done like that
adding the heater hose location to the cold side rad tank might actually be easier - if you can solder
rad solder is 30/70 , same as body lead
I have both types of housing rear nipple outlet and bottom exit nipple
Bottom exit is late , 2.2/2.5 reverse rotation
$25 plus shipping
Discussion Starter #12
Does the bottom outlet differ significantly? How do I know what style should be on my engine? It had the side out but it is a used car so I don't know what would be correct.
I have a deal working on a down outlet but if that wont work I wouldn't want that. I just have the no out let on there now and the heater hose plugged off. But I'm sure we will want the defrost to work come winter time.
Ok I have bottom out and rear out,
The late model pump housing will work on any year, but be warned, you must use the late model smooth pull because the belt turns the pump reverse rotation- as the early.
The housing scroll will be opposite.on the early and the pilot will be grooved.
I think the 89 is the odd ball pulley bolt spacing is odd.
PM me I can send pics if this site will work!
1 - 13 of 13 Posts
