1 - 13 of 13 Posts
I put a new engine in my 1988 Lebaron two years ago. Car finally runs well, but ever since then my Traveler does not do any fuel mileage calculations. I’m wondering if I didn’t hook something back up, or if the unit is bad and it was just a coincidence that it happened after the engine swap. It’s the simple Traveler with just a couple buttons and it powers up and acts normal other than no mpg calculation.
Is your speedometer working?
Besides the Trip Navigator does this vehicle have an Electronic Monitor and/or Electronic Cluster?
Just caught electronic monitor. Is that the display that shows doors open? Mine is the one from a Daytona I swapped in with a boost gauge my Lebaron didn’t have. I haven’t paid attention if that is working.
the 2 button traveler was used on 87-89 Lebarons only
got a pile of them if you need any
4374043 or 4437110 are the Mopar #s
According to the wiring the Trip Navigator, Electronic Monitor and the Electronic Cluster all communicate with each other and the "Distance Signal" travels to all.
Unfortunately I do not know what should be on that line and I do not have any 88 FSM's to check for Diagnostics on the "Traveler System".
I can send you the wiring through PM.
1988 FWD Passenger Car FSM's
https://www.ebay.com/itm/3-1988-CHRYSLER-SERVICE-MANUAL-FRONT-WHEEL-DRIVE-CAR-Engine-Electrical-Wiring-Di/401808411292?hash=item5d8da5ca9c:g:naAAAOSwlbZdIpzu
Discussion Starter #12
Interesting. I was hoping there might have been something simple I left unplugged when I replaced the engine. I thought it was operating properly before then engine swap but I drive it so little I wonder if it had been out for a while. The diagnostic test looks promising.
1 - 13 of 13 Posts
