Alright, I've pulled the ol girl out of the garage to give it another go, that and to save some gas.
I pulled it out, after storing with stabil, probably sat for about a year and a half I started it at least once a month, moved it around, etc and it ran fine.
I drove it a good 400 miles over the course of the last two weeks and it did awesome.
Then it started showing signs of a fuel pump going, which the one in it is the 3rd we've done thanks to shoddy chinese replacements, it died on me and coasted to my house.
Now it sits in my driveway it'll start and run nice for a few second then it gets lopey and dies, sometimes it'll behave as though you just cut the key off. Before the new regulator when it did want to run any interaction with the throttle made it lean out and die.
After the new regulator it fired up and idled smooth, I gave it some gas, it reved normally. Then i brought it up to about 2k and it was like I shut the key off as it had done before. The HEP was replaced as well. Coil throws a nice spark, as do the wires to each cylinder.
I've gone over all the wiring, went through every sticky in the Help section, the only thing left to do is check the timing.
Any ideas? it's got me absolutely baffled. Oh and it isn't throwing any codes.
I can't bring myself to blame the timing though, just because it runs so damn good for a good minute before wanting to die.
EDIT* Already drained the tank, but I may just have some water in there still. At the moment I have it starting and running again but once it shuts down it won't start until you crank it like 6 times for 5-10 seconds a crank. Thinking bad gas, its pretty rich smelling, but not like its clean fuel burning.
