1 - 8 of 8 Posts
1989 Chrysler TC By Maserati. 2.2L SOHC Turbo. Really cool Unique old Convertible. I got this car with the intent of Fully Restoring it but I have too many projects and not enough time. so this one has to go. Car Runs and drives great now. interior and leather is in great shape for it's age. Convertible top is practically new, it's in great shape and i don't think it was used much. I have a TON of new parts and work into this car. All new installed parts are listed below.
  • replacement SMEC computer out of a Shelby
  • Gas tank
  • fuel pump
  • fuel sender
  • all hard bent and soft fuel lines front to back
  • fuel and air filter
  • fuel regulator
  • fuel injectors
  • spark plugs, coil, cap and wires
  • HEP Sensor under Dizzy (OEM hard to find)
  • new brakes all around from master cylinder down
  • brake lines (hard bent and soft)
  • calipers
  • rotors
  • park Brake cables
  • ABS sensors and tone rings
  • rear wheel bearings
  • alternator
  • timing belt and tensionser
  • all other belts
  • Front turn signal mounts and LED bulbs
  • all new vacuum lines under the hood
  • new Convertible top motor
  • freshly undercoated
The cons: There is a few rust spots that could stand to be dealt with. (They're small and could be fixed by a do-it-yourself-er) Missing a piece or two of exterior trim. Could use a new muffler.
270469
270470
270471
270472
270473
270474
1 - 8 of 8 Posts
