I am parting out an 89 Daytona C/S, car has a grey interior in excellent shape, the front seats are already sold, as are the hubs, brake parts, and windshield, almost everything else is available, shipping isn't an issue on smaller things, but i might not have boxes for larger things. the best way to contact me is to call or text me. 414 861 8431 my name is mark, possible trade for rampage parts. Motor was locked up from sitting so i took it apart and will sell pieces of it.
2.5L turbo Parts
$10 AC Bracket
$5 Cam Gear
$5 Crank Pulley
$5 Dip Stick
$20 Distributor
$10 Mains (5)
$10 Oil Pan
$5 Timing Belt Tensioner
$10 Water Pump Housing
$5 Waterpump
$5 5spd. Manual Shifter Knob
$20 Motor Mounts (3)
$40 Flywheel
$10 Coil
$25 Starter
$35 Rear Wing
$20 AC Compressor and Hoses
$30 AC/Heater Box
$10 Battery Tray
$20 Boost Gauge
$20 Brake booster
$10 C/S Emblems (2)
$50 C/S Trim 8pc.
$40 Cluster
$35 Clutch Pedal, Brake Pedal and Bracket
$5 Coal Canister
$5 Coolant Overflow Resevoir
$5 Cowl Plastic Screen 3pc
$15 Non power Door Wires harness (2)
$30 Driver Door Glass
$25 Driver Door Window Trim
$20 Electric Mirrors (2)
$25 Factory Jack/Tire Iron
$50 Fenders pair
$50 Front Axles (2)
$20 Front Bumper Support
$30 Front Coil Springs (2)
$10 Front Engine Mount
$10 Front License Plate Bracket
$5 Front side Marker Lense (2)
$2 Gas Cap
$5 Gas Door
$10 Gas Pedal w/ Cable
$50 Hatch, rust free, with glass
$5 Headlight Service Panel
$20 Hideaway Headlight Relay
$15 Hood Hinges (2)
$5 Hood Release Cable
$50 Hood w/Turbo Scoop
$5 ea Inner Fenders
$5 ea Plastic Interior Panels
$50 Interior Wireharness
$20 Motor Brackets (Alternator, etc.) (5)
$50 Nose Cone w/ Hideaway headlights
$5 Brake Release
$20 ea Quarter Windows
$50 Radio Antennae
$30 Rear Axle, no spindles or hubs,
$50 Rear Bumper Cover
$5 Spare Tire Cover
$5 Speedometer Cable
$30 Tilt Steering Column with key
$50 Taillights and mounting panel
$5 Washer Fluid Resevoir
$30 Weatherstrip
$30 Winshield Moulding
$5 Wiper Arms (2)
$15 Wiper Motor
2.5L turbo Parts
$10 AC Bracket
$5 Cam Gear
$5 Crank Pulley
$5 Dip Stick
$20 Distributor
$10 Mains (5)
$10 Oil Pan
$5 Waterpump
$40 Flywheel
$10 Coil
$25 Starter
$35 Rear Wing
$30 AC/Heater Box
$10 Battery Tray
$20 Boost Gauge
$20 Brake booster
$10 C/S Emblems (2)
$50 C/S Trim 8pc.
$40 Cluster
$5 Coal Canister
$50 Fenders pair
$50 Front Axles (2)
$2 Gas Cap
$5 Gas Door
$15 Hood Hinges (2)
$5 ea Inner Fenders
$5 Brake Release
$50 Radio Antennae
$5 Spare Tire Cover
$30 Weatherstrip
$5 Wiper Arms (2)
$15 Wiper Motor
