Hi there...seeing as we're both on *our* side of the border...
...you'll probably get a Fenco reman rack here. They are the most common rebuilders here. They supply to Can. Tire, Napa here, as well as Carquest, You here in Ontario?..the common power rack is a 2.5 ratio item, the fast rack is 2.2 ratio lock to lock. I know the fast rack could be had on Shelby Lancers, as well as Dodges' Lancer Shelby, but I don't know for sure what other cars it was an option on. If by chance your rack IS a fast rack....you don't want to be trading it in for a reman, you may not get a fast rack back, check the ratio before you pull it from the car, if it the *good* rack, get that one rebuilt.
