Sean Hummel
Red Lion 17356
[email protected]
I don't have any feedback.
I have a used 1989 Dodge Shadow ES Turbo Automatic.
It has about 150K Miles. I bought this car recently on ebay, and brought it home, fixed it up and I can't afford to keep it anymore. I've maybe put 1k miles on it since I bought it.
New- Timing belt
Alternator Belt
Manifold Gasket
Headgasket
Vacuum Block and lines
Front Tires
Paint
Rear Struts
O2 Sensor
Spark Plugs
180* Thermostat
Automatic Trans Filter and all new fluid(MOPAR ATF+3)
Fairly Recent Oil change
Cleaned up 2.2 Turbo head
Bad
Heat doesn't work
Rear defrost acts up
One fog Lamp is out
One Power Door Lock doesn't work(Rest do)
All guages work fine, as does the car.
The car is a BRIGHT YELLOW with BLACK TRIM
and has virtually no rust! I say that because even though I haven't seen any doesn't mean there isn't any! Has a cleaned up head and valve cover(not painted, just washed and bead blasted) and the turbo works and boosts fine. The carpet is good and it still has all four original floor mats. No leaks and all the brakes work fine, including e-brake. It has 15" Pumpers with no rash and look very good on the car.
I wanted to sell the car for around 2k for all the work i've put into it and all of the stuff i've replaced and what it cost me. I will put up pictures later. I don't have a chance right now.
ASKING PRICE IS 1500$ OBO
Don't be afraid to ask, I need this car gone!
***EDIT***
The car is getting a fresh PA inspection on the 28th of this month.
Red Lion 17356
[email protected]
New- Timing belt
Alternator Belt
Manifold Gasket
Headgasket
Front Tires
Paint
Rear Struts
O2 Sensor
Spark Plugs
180* Thermostat
Bad
Heat doesn't work
One fog Lamp is out
***EDIT***
