1 - 13 of 13 Posts
I'm looking for the two front airbag impact sensors found on a 1990 Omni or Horizon. It is behind the headlight bezels secured by three 13mm bolts. It should be part number 4504223. There are no other models this part interchanges with because the mounting is different for each car. Let me know what you have.
it looks to be one year only...here's the 1990 part book (SENSOR SECTION):
L-BODY
5226 356 Coolant Dual Therm
5233 088 Oxygen (Use Insulator 4439077)
4504 223 Frt. Airbag Impact
P-BODY
4443 985 Frt. Airbag Impact (Insul. 4439082) (Stamped 4437326)
5233 088 Oxygen (Insul. 4439077)
A-BODY
4443 985 Airbag Impact (Insul. 4439082)
J-BODY
4503 058 Tail Lamp Outage, w/Brkt.
4374 649 Headlamp Outage
4437 691 Ambient Temp., w/Wiring (Overhead Console)
5227 805 Charge Temp., w/Gauge (Use Insul. 4414902)
4339 418 Coolant Fluid Level
4443 914 Air Bag, Frt. Impact
5226 374 Coolant Temp.
5213 629 Detonation (Use Insulator 4124807)
Q-BODY
4425 197 Detonation, w/16-Valve Eng.
5227 805 Charge Temp. (Use Insul. 4414902)
5252 438 Speedometer
G-BODY
4312 108 Headlamp Outage
4437 691 Ambient Temp, w/Wiring (Overhead Console)
5227 805 Charge Temp, w/Gauge (Insul. 4414902)
4443 914 Air Bag, Frt. Impact (Use Mtg. Screws 6501888)
5213 629 Detonation
He hasn't been online since August.
Maybe someone who did some past business with him has a phone number or other contact information??
Maybe you can find those people by browsing his other sales to those other members????
'90 impact sensors are pretty rare, how bad do you want/need them?????
Good Luck on your search!
Sent you a PM
Please reply there
Thx - Andy
L-BODY
I believe the "Coolant Dual Therm" is listed in error in the OE catalog. Both of my 1990 Horizons have the standard 2 pin coolant sensor on the left side (sitting in the car) of the water jacket. It appears to be the same unit listed for every other car in 1990. That would be the5226374 Coolant Temp. I haven't ever seen the 3pin 5226356 in any of my TBI or Turbo II cars and wonder where they are actually used.
1 - 13 of 13 Posts
